Queue Intro Prompt
Discussion in '3CX Phone System - General' started by tsukraw, May 13, 2014.
  1. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    6
    Hey guys,
    So we have a customer that wants a into prompt played before calls go into a queue.
    Queue setup has that option to add a intro prompt. But it appears that option only works when all the agents are busy and it will play the intro prompt prior to hold music...
    Is there any way to get a into prompt to play before ringing the agents?
    Or any creative ideas on how to achieve a setup like this?
    V12sp5.
    Thanks!
  2. tom_ch
    Jul 6, 2011
    69
    Hey
    I do it like this:
    add a digital receptionist and add your Intro prompt there.
    After prompt ends, send the call to the queue.
    In the queue you only add your hold music, no prompt.
    Dirty Workaround :p
  3. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    6
    We thought about that idea but when user the DR you have the "please wait while we transfer your call"
    I know we could probably find that prompt file and replace it but there just seems like there should be a easier way.
  4. tom_ch
    Jul 6, 2011
    69
    I didn't find an easier way yet.
    I just replaced that file with the "empty.wav"
  5. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    6
    Which wav file are you replacing?
    I can seem to find the darn one that is your call is being transferred.
  6. tom_ch
    Jul 6, 2011
    69
    Sorry, I did that for the "Thank you and goodbye" prompt.
    But you should find the other one somewhere in the System Prompts.
