Queue is not able to use v9,v10
Discussion in '3CX Phone System - General' started by qq138302262, Mar 27, 2012.
  1. qq138302262
    Mar 26, 2012
    Install the v9 version later, add queue parameters have the choice, but can't point to determine or cancel also can't click on the application.
    Click on the location is grey.
    Look for the v10s after version, is still unable to click.
    Just install version of what do not set. Added only a few extension, is it was limited or do I have the set did not open?
