Queue isn't registrered
Discussion in '3CX Phone System - General' started by jesperkjeldsen, Jul 10, 2008.
  1. jesperkjeldsen
    Apr 22, 2008
    9
    Hi!
    I have made a queue with number 5040. It works from the start, but after some time (few hours or less) I get this error in the log when someone is calling to the queue:
    [CM503015]: Call(25): Attempt to reach [sip:5040@myservername.dk:5060] failed. Reason: Not Registered
    I have to restart 3CX to get it to work again, but thats now what I want to do with my day ;-)
    Anyone who knows something about it?
    I'm using 3CX 6.0.664.0.
    Regards Jesper
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    what is the destination of the queue, is there an external number involved?
  3. jesperkjeldsen
    Apr 22, 2008
    9
    Nope - it is 3 local extensions.
    Regards
    Jesper
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    Let me have a think about this and see if I can replicate the issue.
    perhaps in the mean time someone else knows the answer, but I do not know at the moment. (sorry).
    H.
  5. Anonymous
    Anonymous Guest
    Are the agents registered and, cruicially, logged in to the queue?
  6. jesperkjeldsen
    Apr 22, 2008
    9
    Two out of the three extensions are logged in and can make calls (and recieve direct calls).
    Regards
    Jesper
  7. jesperkjeldsen
    Apr 22, 2008
    9
    I have a little more from the log her:
    08:13:28.591 Call::Terminate [CM503008]: Call(3): Call is terminated
    08:13:28.575 Call::RouteFailed [CM503015]: Call(3): Attempt to reach [sip:5040@myserver.dk;user=phone] failed. Reason: Not Registered
    08:13:28.544 Call::RouteFailed [CM503015]: Call(3): Attempt to reach [sip:5040@myserver.dk;user=phone] failed. Reason: Not Registered
    08:13:28.544 CallCtrl::eek:nSelectRouteReq [CM503016]: Call(3): Target is not registered: Ext:Ext.5040
    08:13:28.544 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:5040@myserver.dk;user=phone]
    08:13:28.529 Extension::printEndpointInfo [CM505001]: Ext.4000: Device info: Device Identified: [Man: Snom;Mod: 360;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom360/6.5.15] Transport: [sip:xx.xx.xx.xx:5060]
    08:13:28.482 CallCtrl::eek:nIncomingCall [CM503001]: Call(3): Incoming call from Ext.4000 to [sip:5040@myserver.dk;user=phone]
    I have the same problem with ring groups. And it is only nessesary to restart the 3CX PhoneSystem service.
    My 3CX server is connected directly to the internet with a public IP and Windows Firewall turned on.
    The last problem is that when the queues is working, a call to the queue generates at least 3 calls to the member at a time! It's not a bug problem as long as the queue is working, but its frustrating that it looks like your phone is receiving 3 or more calls at a time!
    Hope someone can help as the problems gets bigger every day :-/
    Regards
    Jesper
  8. Anonymous
    Anonymous Guest
    To get technical support on this one, you can contact our technical support (This requires commercial edition with support package). If you have a commercial edition, but no support package, you can purchase one here:
    https://erp.3cx.com/orderform/support.aspx
  9. jspearso
    Aug 16, 2008
    8
    has anyone come up with a soulution to this i cant ring through to voicemail or a queue even some auto receptions dont work error lists as follows
    11:13:21.156 Call::RouteFailed [CM503015]: Call(7): Attempt to reach [sip:1101@203.38.34.80:5060] failed. Reason: Not Registered
    11:13:21.125 Call::RouteFailed [CM503015]: Call(7): Attempt to reach [sip:1101@203.38.34.80:5060] failed. Reason: Not Registered
    11:13:21.125 CallCtrl::eek:nSelectRouteReq [CM503016]: Call(7): Target is not registered: Ext:Ext.1101
    11:13:21.125 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:1101@203.38.34.80:5060]
    11:13:21.109 Extension::printEndpointInfo [CM505001]: Ext.5844: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 6.0.727.0] Transport: [sip:203.38.34.80:5060]
    11:13:21.062 CallCtrl::eek:nIncomingCall [CM503001]: Call(7): Incoming call from Ext.5844 to [sip:1101@203.38.34.80:5060]
    11:13:17.812 Call::Terminate [CM503008]: Call(6): Call is terminated
    11:13:17.781 Call::RouteFailed [CM503015]: Call(6): Attempt to reach [sip:8003@203.38.34.80:5060] failed. Reason: Not Registered
    11:13:17.750 Call::RouteFailed [CM503015]: Call(6): Attempt to reach [sip:8003@203.38.34.80:5060] failed. Reason: Not Registered
    11:13:17.750 CallCtrl::eek:nSelectRouteReq [CM503016]: Call(6): Target is not registered: Ext:Ext.8003
    11:13:17.750 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:8003@203.38.34.80:5060]
    11:13:17.750 Extension::printEndpointInfo [CM505001]: Ext.5844: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 6.0.727.0] Transport: [sip:203.38.34.80:5060]
    11:13:17.687 CallCtrl::eek:nIncomingCall [CM503001]: Call(6): Incoming call from Ext.5844 to [sip:8003@203.38.34.80:5060]
    11:12:25.640 ExtnCfg::updateContact [CM504002]: Ext.8000: a contact is unregistered. Contact(s): []
    11:12:25.625 ExtnCfg::updateContact [CM504002]: Ext.1101: a contact is unregistered. Contact(s): []
    11:12:24.765 ExtnCfg::updateContact [CM504002]: Ext.8003: a contact is unregistered. Contact(s): []
    11:11:58.406 MediaServerReporting::RTPReceiver [MS105000] C:5.1: No RTP packets were received:remoteAddr=192.168.0.97:42000,extAddr=0.0.0.0:0,localAddr=203.38.34.80:7196
    For Some Reason ext 8000 (auto reception) ext 1101 (voice Mail) and ext 8003) Call Queue keep un registering to fix i have to restart phone system service which gets very annoying
    i am using the latest version of 3cx and do not want to pay for support untill i am happy with the product also i am using a tial key
    cheers
    josh
  10. jspearso
    Aug 16, 2008
    8
    fixed it by lodading software on a windows server dont know y it works now but it wouldnt on windows xp
    mayby a bug in current update
    ps i still love the prgram though slowly working through it all
    cheers
    Josh
