Queue with no music
Discussion in '3CX Phone System - General' started by adamwells, May 11, 2015.
  1. adamwells
    Mar 20, 2015
    25
    I'm attempting to create the following set up
    User calls > rings directly to one of three users within a queue with no music
    Currently, the hold music plays whilst they ring in. Can this be changed so it's a ringing tone? It works perfectly with a ring group, but this gets rid of the wallboard so the users don't know if someone else is ringing in.
    What's the closest way I can achieve it?
  2. mattscott
    Dec 21, 2008
    12
    I needed to do something similar once and I ended up using a file like this as the hold music for the queue.
    http://soundbible.com/1868-Ringing-Phone.html
  3. gbardissi
    Feb 4, 2015
    28
    Yes you can add an audio file to the queue configuration with silence or do what you did with the ring groups by adding an audio file with just rining.
  4. leejor
    10,375
    231
    Keep in mind that callers are usually only willing to wait so long, if they are listening to ringback tone, or (even worse) silence (did they hang up on me?). The music, in a queue, confirms that they are on hold, and that the wait time could be a few minutes. Ringback tone has callers picturing a set actually ringing somewhere, and perhaps someone sitting beside it ignoring it. If not answered within a reasonable time (30 to 45 seconds), they will hang up and (possibly) try again.
  5. adamwells
    Mar 20, 2015
    25
    Perfect. Thank you very much - it's now exactly how we want it!
  6. adamwells
    Mar 20, 2015
    25
    Thanks for the input - our company doesn't have a high volume of calls, so it's a rarity that there is no one to answer - in which case it goes over to a group after a minute. The ring tone suits us perfect at our current size. :D
