queues login and out.
Discussion in '3CX Phone System - General' started by aly@accendo.dk, Jul 5, 2011.
  1. aly@accendo.dk
    Jun 15, 2011
    22
    Does anyone know if the call center module enables user to log out of one queues and still be in another queue??
    Is there anyway to to this with 3cx??
    Alex
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    yes this is possible with the Call Center Module. Managers can log agents out of one or more queues.
    Thanks,
    Nate
  3. aly@accendo.dk
    Jun 15, 2011
    22
    Hi Nate
    Thanks for the answar - is it allso possible for the agents to deside that they want to be in one queu and not another? If not - can I create agents as managers?
    Alex
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Hello Alex,
    Yes but this depends on the Administrator and how you setup extension groups. All rights depend on how you set this up.
    Thanks,
    Nate
  5. aly@accendo.dk
    Jun 15, 2011
    22
    We are using 3cx with the call center function. And after the service pack update I was hoping what it was possible to log in and out off differne qeues, but no.
    As far as I can see, the extension is either in a queu or out off all qeues.
    Does anyone know it this is changed in a furture update?
    Alex
