Queues not forwarding after timeout
Discussion in '3CX Phone System - General' started by Prometheus DBA, Feb 14, 2018.
  1. Prometheus DBA
    Mar 7, 2017
    54
    Since the latest service pack we experience that calls coming in our main queue are not being forwarded to the specified queue after the timeout period. What can I do to fix this, cause we are missing a lot of calls this way.
  2. Prometheus DBA
    Mar 7, 2017
    54
    Anyone who knows what to do or what tot test in this situation?
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,422
    538
    Hello @Prometheus DBA
    Can you please let me know the master timeout of the Queue as well as the ringing timeout? Also what is the duration of your music on hold?
  4. Prometheus DBA
    Mar 7, 2017
    54
    Hi Yiannish Master, and ringing timeout is both set on 120 seconds. Hold music is USprogressive.
  5. YiannisH_3CX
    May 10, 2016
    7,422
    538
    This is a known issue and we are currently looking into this. Can you please set your timers to 125 seconds and try again?
  6. Prometheus DBA
    Mar 7, 2017
    54
    @YiannisH_3CX does this help? And is there comming a patch for this cause this is a crucial fault for us.
  7. YiannisH_3CX
    May 10, 2016
    7,422
    538
    The issue will be addressed in the next release. I have replicated your issue and setting the timers to 125 seconds bypasses the issue
  8. Prometheus DBA
    Mar 7, 2017
    54
    Hi Yiannish_3CX, your solution seems to work. Thank you for that. For now it will do as a work arround, but when will the next patch be released? cause I have multiple queues, and i dont want them all with a timeout of 125 seconds.
  9. YiannisH_3CX
    May 10, 2016
    7,422
    538
