Quick connect and disconnect 3CX iPhone app
Discussion in 'Ideas' started by Nicolas V., Aug 31, 2017.
  1. Nicolas V.
    Aug 31, 2017
    19
    A client asked me if it was possible to have a simplified access to the account action, connect and disconnect. To avoid the change of the presence profile and to have a function like the android application that allows to quit and ignore the push easily.
