quick dial
Discussion in '3CX Phone System - General' started by mckey415, Oct 9, 2007.
  1. mckey415
    Jun 27, 2007
    24
    hi all!
    is it possible to have a kind of quick dial in 3CX? For example i dial 0 and connect to digital receptionist with ext 8000?
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Not that I know of. Most phones have their own programmable directories of that be a workaround for you.
