quick question Re: pstn and voip
Discussion in 'Windows' started by iperez_genius, Jul 3, 2008.
  1. iperez_genius
    Jul 1, 2008
    56
    do i need a pstn line setup on the server inorder for a voip line to work?
  2. francesco
    francesco New Member
    Jun 23, 2008
    102
    you have need to only a SIP account
  3. Henk
    Henk Member
    Nov 13, 2007
    250
    Out going calls.
    For internal (eg no network outbound calls) you do not need PSTN or SIP.
    For External using PSTN network, you need a PSTN line and an ATA.
    For External using VOIP (eg broadband) you need a VSP with a SIP account, no ATA is needed as the 3CX box registers direct with your VSP.
    Same applies for incomming calls.
    Hope this helps.
    H.
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    Nope, sip is just one of the many signalling protocols like:
    - QSIG
    - H.225.0
    - ISND
    - SS7
    - H.248
    - Session Initiation Protocol (SIP)
    - H.323
    - MGCP
    - C7
    - C5
    - DTMF
    - R1
    - R2
    For good order, and in the context of this forum you are correct.
    But you do not need to setup a SIP account as such simply becasue 3CX is your IP-PBX.
    But the questions was "do i need a pstn line setup on the server inorder for a voip line to work?" and the answer provided is No which is correct technically.
