QUINTUM INTEGRATION
Discussion in 'Windows' started by tech_john, Jul 24, 2008.
  1. tech_john
    Jul 21, 2008
    Hi to All,
    Good day,
    Am treing to configure quintum AFM200 for 3CX.
    1.) i tried to setup extension for quintum and registered --- successfull
    2.) i tried to setup extension x-lite and registered --- successfull
    3.) i tried to setup extesion for quintum as FXO/CO and registered --- successfull
    4.) using the 4 as dialing out --- successfull
    5.) i tried calling receptionist from x-lite ---- successfull
    6.) i tried calling receptionist from quintum extention --- successfull
    7.) from PSTN>quintum>3CX> receptionist/ip extension --- failed
    Hope you can give me some hints how to configure the parameters.
    Thanks in advance.
  2. dmatthysen
    Aug 29, 2008
    Did you succeed??
  3. charlief
    Aug 30, 2008
    9
    I am trying to do the same on a Quintum ASM400 (which for all intensive purposes is the same. Just started. I will let you know how I get on. Any progress with you?
  4. charlief
    Aug 30, 2008
    9
    Hi tech_john (or anybody who can help)
    I have Quintum ASM400 and I want to use it to connect to PSTN.
    I get this (see below). Does anyone know the config parameters for a Quintum?
    I am using a Lnksys PAP2 as the extension and I can dial out to Voip OK, but the Quintum has me defeated! Unsupported Media type?!
    01:07:34.406 Call::Terminate [CM503008]: Call(10): Call is terminated
    01:07:34.359 Call::RouteFailed [CM503015]: Call(10): Attempt to reach [sip:908232721059@192.168.0.2] failed. Reason: Unsupported Media Type
    01:07:34.359 CallLeg::eek:nFailure [CM503003]: Call(10): Call to sip:08232721059@192.168.0.16:5060 has failed; Cause: 415 Unsupported Media Type; from IP:192.168.0.16:5060
    01:07:34.093 CallLeg::eek:nFailure [CM503003]: Call(10): Call to sip:08232721059@192.168.0.16:5060 has failed; Cause: 415 Unsupported Media Type; from IP:192.168.0.16:5060
    01:07:33.843 CallLeg::eek:nFailure [CM503003]: Call(10): Call to sip:08232721059@192.168.0.16:5060 has failed; Cause: 415 Unsupported Media Type; from IP:192.168.0.16:5060
    01:07:33.578 CallLeg::eek:nFailure [CM503003]: Call(10): Call to sip:08232721059@192.168.0.16:5060 has failed; Cause: 415 Unsupported Media Type; from IP:192.168.0.16:5060
    01:07:33.359 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(10): Calling: PSTNline:08232721059@(Ln.10001@Quintum)@[Dev:sip:10001@192.168.0.16:5060, Dev:sip:10002@192.168.0.16:5061, Dev:sip:10003@192.168.0.16:5062, Dev:sip:10004@192.168.0.16:5063]
    01:07:33.343 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:908232721059@192.168.0.2]
    01:07:33.343 Extension::printEndpointInfo [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/PAP2-3.1.22(LS)] Transport: [sip:192.168.0.2:5060]
    01:07:33.312 CallCtrl::eek:nIncomingCall [CM503001]: Call(10): Incoming call from Ext.10 to [sip:908232721059@192.168.0.2]
  5. dmatthysen
    Aug 29, 2008
    PM me; I have a working config. I`m a Quintum Engineer and can assist.
  6. hanserian
    Nov 24, 2008
    Dears,
    Am facing the same problem if anyone can upload or send me the config for Quintum ASM200 for 3CX would be highly appreciative.
    Regards,
    Hagop
  7. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,888
    190
    We dont support Quintum with 3CX, its best you use a supported gateway.
  8. charlief
    Aug 30, 2008
    9
    By the way, I have the ASM400 up and running perfectly now, so if anyone needs the config just PM me.
  9. heinbense
    May 28, 2008
    Hi charlief, can you send me the config please?
  10. xavcastro
    Jun 1, 2015
    Hi charlief. Can you send me the config for the ASM 400 and a brief instrtuctions on how to set it up for 3cx. Thanks.
