Random dial out issues
Discussion in '3CX Phone System - General' started by dantell, Feb 2, 2010.
  1. dantell
    Jul 2, 2008
    17
    I get a lot of random reports of phone issues and have trouble locating a problem. Two of my extensions started having issues today, they resolved themselves shortly afterwards. Neither one could dial out. the only entry that looked interesting was:
    09:07:37.069 [MS004000] C:360.1: (ACTIVE): Can't send RTP stream to 192.168.10.85:53228 destination unreachable
    I am running SNOM 300s and the latest 8 version of 3cx.
    I have a 4 line patton and a SIP trunk to NexVortex.
    The above error is from one of the extensions that couldnt make an outbound call.
  2. dantell
    Jul 2, 2008
    17
    More info:
    10:31:09.364 [MS003005] C:424.2: Failed to create Endpoint: (destination=xx.xx.xxx.253)EndPoint: ID=00000443@(EXTERNAL) LOGID=C:424.2 Status: MSEP_FAILED RTP:0.0.0.0:0 RTCP:0.0.0.0:0 STUN RTP:0.0.0.0:0 STUN RTCP:0.0.0.0:0 Coder: NOT SET 101:telephony-event Party ptime:20 Party RTP:0.0.0.0:0 Party RTCP:0.0.0.0:0 Decoders: <empty>
    10:31:09.364 [MS006000] C:424.2: No ports available to create EXTERNAL enpoint
    It has been working mostly ok until today. Now i get this from different extensions trying to make outbound calls.
