11:38:25.874|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 xxx.xxx.xxx.xxx:5064 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:32.663|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:32.663|TransactionUser.cxx(66)|Debug8|Resip|>>:Checking if SipReq: INVITE
[email protected]:5060 tid=2952864c1FB29883 cseq=INVITE
[email protected] / 1 from(wire) is for me
11:38:32.663|TransactionUser.cxx(71)|Debug8|Resip|>>:Checking rule...
11:38:32.663|MessageFilterRule.cxx(42)|Debug8|Resip|>>:Matching rule for INVITE sip:
[email protected]:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx;branch=z9hG4bK2952864c1FB29883
Max-Forwards: 70
Contact: <sip:
[email protected]>
To: <sip:
[email protected];user=phone>
[email protected]>;tag=506BBA06-DCA308FF
Call-ID:
[email protected]
CSeq: 1 INVITE
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, MESSAGE, SUBSCRIBE, NOTIFY, PRACK, UPDATE, REFER
Content-Type: application/sdp
Supported: 100rel, replaces
User-Agent: PolycomSoundPointIP-SPIP_501-UA/1.6.7.0098
Allow-Events: talk, hold, conference
Content-Length: 223
v=0
o=- 1186070618 1186070618 IN IP4 xxx.xxx.xxx.xxx
s=Polycom IP Phone
c=IN IP4 xxx.xxx.xxx.xxx
t=0 0
a=sendrecv
m=audio 2252 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
11:38:32.663|TransactionUser.cxx(74)|Debug8|Resip|>>:Match!
11:38:32.663|Helper.cxx(302)|Debug8|Resip|>>:Helper::makeResponse(SipReq: INVITE
[email protected] / 1 from(wire) code=100 reason=
11:38:32.663|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer Trying tid=2952864c1FB29883 ms=80
11:38:32.663|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 INVITE sip:
Max-Forwards: 70
Contact: <sip:
[email protected]>
To: <sip:
Call-ID:
[email protected]
CSeq: 1 INVITE
Content-Length: 223
v=0
s=Polycom IP Phone
t=0 0
a=sendrecv
11:38:32.663|.\Authorization.cpp(165)|Message5|Authorization|AuthMgr::handle:handle:
INVITE sip:
Max-Forwards: 70
Contact: <sip:
[email protected]>
To: <sip:
Call-ID:
[email protected]
CSeq: 1 INVITE
Content-Length: 223
v=0
s=Polycom IP Phone
t=0 0
a=sendrecv
11:38:32.663|DialogSetId.cxx(31)|Debug8|Resip|>>:********** Generated Local Tag ***********
11:38:32.663|DialogId.cxx(50)|Debug8|Resip|>>
ialogId:
ialogId: cbff894a-53ba7288-26a74fa1@xxx.xxx.xxx.xxx-57102d61-506BBA06-DCA308FF
11:38:32.663|.\Authorization.cpp(216)|Debug2|Authorization|AuthMgr::handle:Invite session is not found
11:38:32.673|Helper.cxx(302)|Debug8|Resip|>>:Helper::makeResponse(SipReq: INVITE
[email protected] / 1 from(wire) code=407 reason=
11:38:32.673|ServerAuthManager.cxx(363)|Trace5|Resip|>>:Sending challenge to SipReq: INVITE
11:38:32.673|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: SIP/2.0 407 Proxy Authentication Required
Proxy-Authenticate: Digest nonce="12830553512:dd06d8c78149a912f327c8a6bb9d3969",algorithm=MD5,realm="3CXPhoneSystem"
To: <sip:
[email protected];user=phone>;tag=620a5320
Call-ID:
[email protected]
CSeq: 1 INVITE
User-Agent: 3CXPhoneSystem
Content-Length: 0
11:38:32.673|SipStack.cxx(278)|Debug8|Resip|>>:SEND: SipResp: 407 tid=2952864c1FB29883 cseq=INVITE / 1 from(tu)
11:38:32.673|ServerAuthManager.cxx(41)|Trace5|Resip|>>:ServerAuth challenged request SipReq: INVITE
11:38:32.763|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer H tid=2952864c1FB29883 ms=32000
11:38:32.763|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer G tid=2952864c1FB29883 ms=500
11:38:32.763|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 xxx.xxx.xxx.xxx:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by=xxx.xxx.xxx.xxx sent-port=0
11:38:32.763|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]SIP/2.0 407 Proxy Authentication Required
To: <sip:
Call-ID:
[email protected]
CSeq: 1 INVITE
Content-Length: 0
11:38:32.763|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:32.833|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:32.833|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer I tid=2952864c1FB29883 ms=5000
11:38:32.843|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:32.843|TransactionUser.cxx(66)|Debug8|Resip|>>:Checking if SipReq: INVITE
[email protected]:5060 tid=c196bc9d2884D7C4 cseq=INVITE
[email protected] / 2 from(wire) is for me
11:38:32.843|TransactionUser.cxx(71)|Debug8|Resip|>>:Checking rule...
11:38:32.843|MessageFilterRule.cxx(42)|Debug8|Resip|>>:Matching rule for INVITE sip:
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx;branch=z9hG4bKc196bc9d2884D7C4
Max-Forwards: 70
Contact: <sip:
[email protected]>
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Proxy-Authorization: Digest username="211", realm="3CXPhoneSystem", nonce="12830553512:dd06d8c78149a912f327c8a6bb9d3969", uri="sip:
[email protected]:5060;user=phone", response="d7e84d88f902ec5d33bc19928cd6c582", algorithm=MD5
Content-Length: 223
v=0
s=Polycom IP Phone
t=0 0
a=sendrecv
11:38:32.843|TransactionUser.cxx(74)|Debug8|Resip|>>:Match!
11:38:32.843|Helper.cxx(302)|Debug8|Resip|>>:Helper::makeResponse(SipReq: INVITE
[email protected] / 2 from(wire) code=100 reason=
11:38:32.843|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer Trying tid=c196bc9d2884D7C4 ms=80
11:38:32.843|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 INVITE sip:
Max-Forwards: 70
Contact: <sip:
[email protected]>
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 223
v=0
s=Polycom IP Phone
t=0 0
a=sendrecv
11:38:32.843|.\Authorization.cpp(165)|Message5|Authorization|AuthMgr::handle:handle:
INVITE sip:
Max-Forwards: 70
Contact: <sip:
[email protected]>
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 223
v=0
s=Polycom IP Phone
t=0 0
a=sendrecv
11:38:32.843|DialogSetId.cxx(31)|Debug8|Resip|>>:********** Generated Local Tag ***********
11:38:32.843|DialogId.cxx(50)|Debug8|Resip|>>
ialogId:
ialogId: cbff894a-53ba7288-26a74fa1@xxx.xxx.xxx.xxx-5f07de66-506BBA06-DCA308FF
11:38:32.843|.\Authorization.cpp(216)|Debug2|Authorization|AuthMgr::handle:Invite session is not found
11:38:32.843|ServerAuthManager.cxx(307)|Trace5|Resip|>>:Requesting credential for 211 @ 3CXPhoneSystem
11:38:32.843|Helper.cxx(801)|Debug8|Resip|>>:Authenticating: realm=3CXPhoneSystem expires=0
11:38:32.843|Helper.cxx(865)|Trace5|Resip|>>: username=211 password=211 realm=3CXPhoneSystem method=INVITE uri=sip:
[email protected]:5060;user=phone nonce=12830553512:dd06d8c78149a912f327c8a6bb9d3969
11:38:32.843|ServerAuthManager.cxx(47)|Trace5|Resip|>>:ServerAuth requested credentials SipReq: INVITE
11:38:32.843|ServerAuthManager.cxx(125)|Trace5|Resip|>>:Checking for auth result in realm=3CXPhoneSystem A1=
11:38:32.843|ServerAuthManager.cxx(210)|Trace5|Resip|>>:Authorized request for 3CXPhoneSystem
11:38:32.843|.\Authorization.cpp(294)|Trace5|Authorization|AuthMgr:
nAuthSuccess:Caller "211"<sip:
[email protected]>;tag=506BBA06-DCA308FF has been authenticated successfully
11:38:32.843|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: INVITE
11:38:32.843|DialogUsageManager.cxx(1456)|Debug8|Resip|>>
ialogUsageManager:
rocessRequest: SipReq: INVITE
11:38:32.843|DialogSet.cxx(84)|Debug8|Resip|>>: ************* Created DialogSet(UAS) --
[email protected]*************
11:38:32.843|.\CallMgr.cpp(349)|Trace5|CallControl|ADSFactory::createAppDialogSet:Creating ADS for INVITE
11:38:32.843|.\CallConf.cpp(506)|Trace5|CallControl|CallConf::CallConf:Call created: 26
11:38:32.843|.\CallConf.cpp(445)|Trace5|CallControl|CallConf::addCallLeg:Added leg# 1 to call 26
11:38:32.843|.\Call.cpp(1372)|Trace5|CallControl|CallLegImpl::CallLegImpl:Leg @L:1@C:1a is created
ialogId:
ialogId: cbff894a-53ba7288-26a74fa1@xxx.xxx.xxx.xxx-9a12036c-506BBA06-DCA308FF
11:38:32.843|DialogSet.cxx(717)|Debug8|Resip|>>:Creating a new Dialog from msg: INVITE sip:
Max-Forwards: 70
Contact: <sip:
[email protected]>
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Proxy-Authorization: Digest username="211",realm="3CXPhoneSystem",nonce="12830553512:dd06d8c78149a912f327c8a6bb9d3969",uri="sip:
[email protected]:5060;user=phone",response="d7e84d88f902ec5d33bc19928cd6c582",algorithm=MD5
Content-Length: 223
v=0
s=Polycom IP Phone
t=0 0
a=sendrecv
11:38:32.843|Dialog.cxx(87)|Debug8|Resip|>>:UAS dialog ID creation, DS:
[email protected]
11:38:32.843|DialogId.cxx(63)|Debug8|Resip|>>
ialogId:
ialogId: cbff894a-53ba7288-26a74fa1@xxx.xxx.xxx.xxx-8a33b41f-506BBA06-DCA308FF
11:38:32.843|Dialog.cxx(129)|Debug8|Resip|>>:************** Created Dialog as UAS **************
11:38:32.843|Dialog.cxx(130)|Debug8|Resip|>>:mRemoteNameAddr: "211"<sip:
11:38:32.843|Dialog.cxx(131)|Debug8|Resip|>>:mLocalNameAddr: <sip:
[email protected];user=phone>;tag=8a33b41f
11:38:32.843|Dialog.cxx(132)|Debug8|Resip|>>:mLocalContact: <sip:
[email protected]:5060;user=phone>
11:38:32.843|Dialog.cxx(133)|Debug8|Resip|>>:mRemoteTarget: <sip:
[email protected]>
11:38:32.843|Dialog.cxx(214)|Debug8|Resip|>>
ialog:
ialog cbff894a-53ba7288-26a74fa1@xxx.xxx.xxx.xxx-8a33b41f-506BBA06-DCA308FF
11:38:32.843|DialogSet.cxx(755)|Debug8|Resip|>>:### Calling CreateAppDialog ### INVITE sip:
Max-Forwards: 70
Contact: <sip:
[email protected]>
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 223
v=0
s=Polycom IP Phone
t=0 0
a=sendrecv
11:38:32.843|Dialog.cxx(300)|Debug8|Resip|>>
ialog::dispatch: SipReq: INVITE
11:38:32.843|KeepAliveManager.cxx(19)|Debug8|Resip|>>:First keep alive for: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:32.843|KeepAliveManager.cxx(20)|Debug8|Resip|>>:Keepalive interval 30 seconds
11:38:32.843|KeepAliveManager.cxx(21)|Debug8|Resip|>>:Keepalive id 37
11:38:32.853|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](37)
11:38:32.853|Dialog.cxx(332)|Debug8|Resip|>>
ialog::dispatch -- Created new server invite sessionSipReq: INVITE
11:38:32.853|InviteSession.cxx(73)|Debug8|Resip|>>:^^^ InviteSession::InviteSession 0179F698
11:38:32.853|SipMessage.cxx(964)|Debug8|Resip|>>:SipMessage::getContents: application/sdp
11:38:32.853|Helper.cxx(1902)|Debug8|Resip|>>:Got sdp
11:38:32.853|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_Start -> UAS_Offer
11:38:32.853|.\ISHandler.cpp(21)|Trace5|CallControl|ISHandler:
nNewSession:Incoming: sis=7605;oat=Offer;rl=INVITE sip:
11:38:32.853|.\Endpoint.cpp(35)|Trace5|Endpoint|Endpoint::findSource:Settings for caller is found: CfgExt:211
11:38:32.853|UserProfile.cxx(135)|Debug8|Resip|>>:Adding credential: realm=3CXPhoneSystem user=internal
11:38:32.853|.\Call.cpp(125)|Trace5|CallControl|CallLegImpl:
nIncoming:Endpoint is built: Ext.211
11:38:32.863|.\Call.cpp(693)|Trace5|CallControl|CallLegImpl::initMSEndpoint:Created internal MS endpoint for Ext.211: addr=xxx.xxx.xxx.xxx:7074
11:38:32.863|ServerInviteSession.cxx(91)|Trace5|Resip|>>:UAS_Offer: provisional(100)
11:38:32.863|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_Offer -> UAS_EarlyOffer
11:38:32.863|Helper.cxx(302)|Debug8|Resip|>>:Helper::makeResponse(SipReq: INVITE
11:38:32.863|Dialog.cxx(970)|Debug8|Resip|>>
ialog::makeResponse: SIP/2.0 100 Trying
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 0
11:38:32.863|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: DumTimeout::Retransmit1xx INVITE: 7605 UAS_EarlyOffer ADDR=<sip:
[email protected];user=phone>;tag=8a33b41f PEER="211"<sip:
[email protected]>;tag=506BBA06-DCA308FF: duration=60 seq=2
11:38:32.863|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler:
nReadyToSend:InviteSession(7605) sends SIP/2.0 100 Trying
11:38:32.863|.\ISHandler.cpp(141)|Message5|CallControl|ISHandler:
nReadyToSend:IS(7605) sends:
SIP/2.0 100 Trying
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 0
11:38:32.863|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: SIP/2.0 100 Trying
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 0
11:38:32.863|SipStack.cxx(278)|Debug8|Resip|>>:SEND: SipResp: 100 tid=c196bc9d2884D7C4 cseq=INVITE / 2 from(tu)
11:38:32.863|.\CallConf.cpp(120)|Log2|CallControl|CallConf:
nIncoming:[CM103002] Call(26): Incoming call from 211 (Ext.211) to sip:
[email protected]
11:38:32.863|.\CallStrategies.cpp(439)|Trace5|CallManager|StratInOut::initialize:Initialize InOut call strategy
11:38:32.873|.\DBAccessor.cpp(1222)|Trace5|DataBase|DBPostgressAccessor::findDestinationsEx:Will use outbound rule rule ID=1
11:38:32.893|.\CallTarget.cpp(374)|Trace5|CallManager|CT_Lines::selectNextTarget:Select new line for outbound call
11:38:32.944|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 xxx.xxx.xxx.xxx:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by=xxx.xxx.xxx.xxx sent-port=0
11:38:32.944|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]SIP/2.0 100 Trying
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 0
11:38:32.944|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:33.114|.\Call.cpp(693)|Trace5|CallControl|CallLegImpl::initMSEndpoint:Created external MS endpoint for Ln:10001@BroadVoice 2: addr=xxx.xxx.xxx.xxx:9002
11:38:33.114|.\CallConf.cpp(445)|Trace5|CallControl|CallConf::addCallLeg:Added leg# 2 to call 26
11:38:33.114|UserProfile.cxx(135)|Debug8|Resip|>>:Adding credential: realm=3CXPhoneSystem user=XXXXXXXXXX
11:38:33.114|UserProfile.cxx(135)|Debug8|Resip|>>:Adding credential: realm=sip.broadvoice.com user=XXXXXXXXXX
11:38:33.114|.\Call.cpp(1372)|Trace5|CallControl|CallLegImpl::CallLegImpl:Leg 10001@L:2@C:1a is created
11:38:33.114|.\CallTarget.cpp(389)|Trace5|CallManager|CT_Lines::selectNextTarget:Line Ln:10001@BroadVoice 2 is found for outbound call
11:38:33.394|.\CallConf.cpp(132)|Trace5|CallControl|CallConf:
nIncoming:MediaServer could be used for this call
11:38:33.394|.\ISHandler.cpp(157)|Trace5|CallControl|ISHandler:
nOffer:Offered: is=7605; rl=INVITE sip:
11:38:33.394|.\Call.cpp(195)|Message5|CallControl|CallLegImpl:
nOfferProvided:Leg.onOffer 211@L:1@C:1a got:
INVITE sip:
Max-Forwards: 70
Contact: <sip:
[email protected]>
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 223
v=0
s=Polycom IP Phone
t=0 0
a=sendrecv
11:38:33.394|.\CallStrategies.cpp(643)|Trace5|CallManager|StratInOut:
nOffer:InOut: got offer from 211@L:1@C:1a
11:38:33.394|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Calling; DN 211
11:38:33.394|.\CallTarget.cpp(443)|Trace5|CallManager|CT_Lines::Invite:Rule (Outbound 1): Placing call to line 10001@L:2@C:1a to reach XXXXXXX
11:38:33.394|BaseCreator.cxx(127)|Debug8|Resip|>>:BaseCreator::makeInitialRequest: 017D8B88
11:38:33.394|DialogSet.cxx(52)|Debug8|Resip|>>: ************* Created DialogSet(UAC) -- ZjFkNjBlOWFkYTQzZjNiN2M2NTJmNzhjZWU0YmNlYWM.-7758bb08*************
11:38:33.394|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: INVITE sip:
[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d87543-3606515efb52c962-1--d87543-;rport
Max-Forwards: 70
Contact: <sip:
[email protected]:5060>
To: "XXXXXXX"<sip:
[email protected]>;tag=7758bb08
Call-ID: ZjFkNjBlOWFkYTQzZjNiN2M2NTJmNzhjZWU0YmNlYWM.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
Content-Length: 246
v=0
o=3cxPS 12830553512893 12830553512894 IN IP4 xxx.xxx.xxx.xxx
s=3cxPS Audio call
t=0 0
m=audio 9002 RTP/AVP 0 8 3 101
a=rtpmap:3 GSM/8000
11:38:33.394|DialogId.cxx(50)|Debug8|Resip|>>
ialogId:
ialogId: ZjFkNjBlOWFkYTQzZjNiN2M2NTJmNzhjZWU0YmNlYWM.-7758bb08-
11:38:33.394|DialogUsageManager.cxx(912)|Debug8|Resip|>>:Using outbound proxy: sip:
[email protected]:5060;lr -> SipReq: INVITE
[email protected]:5060 tid=3606515efb52c962 cseq=INVITE
[email protected]:5060 / 1 from(tu)
11:38:33.394|.\Call.cpp(770)|Message5|CallControl|CallLegImpl::Invite:Sent:
INVITE sip:
Max-Forwards: 70
Contact: <sip:
To: "XXXXXXX"<sip:
CSeq: 1 INVITE
Content-Length: 246
v=0
s=3cxPS Audio call
t=0 0
a=rtpmap:3 GSM/8000
11:38:33.444|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer B tid=3606515efb52c962 ms=32000
11:38:33.444|DnsResult.cxx(186)|Debug8|Resip|>>
nsResult::lookup sip:
11:38:33.444|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer A tid=3606515efb52c962 ms=500
11:38:33.444|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 147.135.12.221:5060 UDP target domain=sip.broadvoice.com connectionId=0 ] -> [ V4 xxx.xxx.xxx.xxx:0 UDP target domain=sip.broadvoice.com connectionId=0 ] sent-by= sent-port=0
11:38:33.444|TransportSelector.cxx(971)|Debug8|Resip|>>:findTransportBySource([ V4 xxx.xxx.xxx.xxx:0 UDP target domain=sip.broadvoice.com connectionId=0 ])
11:38:33.444|TransportSelector.cxx(1083)|Debug8|Resip|>>:findTransport (any port, any interface) => Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ]
11:38:33.444|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 147.135.12.221:5060 UDP target domain=sip.broadvoice.com received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=sip.broadvoice.com connectionId=0 ]INVITE sip:
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK-d87543-3606515efb52c962-1--d87543-;rport
Max-Forwards: 70
Contact: <sip:
To: "XXXXXXX"<sip:
CSeq: 1 INVITE
Content-Length: 246
v=0
s=3cxPS Audio call
t=0 0
a=rtpmap:3 GSM/8000
11:38:33.444|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 147.135.12.221:5060 UDP target domain=sip.broadvoice.com received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:33.504|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 147.135.12.221:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:33.504|DnsResult.cxx(177)|Debug8|Resip|>>:Whitelisting sip.broadvoice.com(1): 147.135.12.221
11:38:33.504|dns\RRVip.cxx(129)|Debug8|Resip|>>:updating an existing vip: 147.135.12.221 with 147.135.12.221
11:38:33.504|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 SIP/2.0 100 Trying
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK-d87543-3606515efb52c962-1--d87543-;received=xxx.xxx.xxx.xxx;rport=5060
To: "XXXXXXX"<sip:
[email protected]>
CSeq: 1 INVITE
Content-Length: 0
11:38:33.504|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 100 tid=3606515efb52c962 cseq=INVITE / 1 from(wire)
11:38:33.504|DialogUsageManager.cxx(1646)|Debug8|Resip|>>
ialogUsageManager:
rocessResponse: SipResp: 100 tid=3606515efb52c962 cseq=INVITE / 1 from(wire)
11:38:33.564|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 147.135.12.221:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:33.564|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer D tid=3606515efb52c962 ms=32000
11:38:33.564|TransportSelector.cxx(388)|Debug8|Resip|>>:hint provided by app: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK-d87543-3606515efb52c962-1--d87543-;rport
11:38:33.564|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 147.135.12.221:5060 UDP target domain=sip.broadvoice.com received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified connectionId=0 ]ACK sip:
To: "XXXXXXX"<sip:
[email protected]>;tag=npqr
CSeq: 1 ACK
Content-Length: 0
11:38:33.564|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 147.135.12.221:5060 UDP target domain=sip.broadvoice.com received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:33.564|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 SIP/2.0 401 Unauthorized
To: "XXXXXXX"<sip:
CSeq: 1 INVITE
WWW-Authenticate: DIGEST realm="BroadWorks",qop="auth",algorithm=MD5,nonce="BroadWorksXf4vl2ouiTbpvem0BW"
Content-Length: 0
11:38:33.564|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 401 tid=3606515efb52c962 cseq=INVITE / 1 from(wire)
11:38:33.564|DialogUsageManager.cxx(1646)|Debug8|Resip|>>
ialogUsageManager:
rocessResponse: SipResp: 401 tid=3606515efb52c962 cseq=INVITE / 1 from(wire)
11:38:33.564|ClientAuthManager.cxx(219)|Debug8|Resip|>>:ClientAuthManager::RealmState::handleAuth: 0179A690 DIGEST realm="BroadWorks",qop="auth",algorithm=MD5,nonce="BroadWorksXf4vl2ouiTbpvem0BW" is proxy: 0
11:38:33.564|ClientAuthManager.cxx(193)|Debug8|Resip|>>:ClientAuthManager::RealmState::transition from invalid to current
11:38:33.564|UserProfile.cxx(153)|Debug8|Resip|>>
idn't find credential for realm: BroadWorks realm=3CXPhoneSystem user=XXXXXXXXXX
11:38:33.564|ClientAuthManager.cxx(58)|Debug8|Resip|>>
roduced response to digest challenge for UserProfile: "EasyDesk, LLC"<sip:
[email protected]>[realm=3CXPhoneSystem user=XXXXXXXXXX, realm=sip.broadvoice.com user=XXXXXXXXXX]
11:38:33.564|DialogSet.cxx(244)|Debug8|Resip|>>:about to re-send request with digest credentials
11:38:33.564|ClientAuthManager.cxx(313)|Debug8|Resip|>>: Add auth, 0179A690 in response to: DIGEST realm="BroadWorks",qop="auth",algorithm=MD5,nonce="BroadWorksXf4vl2ouiTbpvem0BW"
11:38:33.564|Helper.cxx(1125)|Debug8|Resip|>>:nonceCount is now: [00000001]
11:38:33.564|ClientAuthManager.cxx(321)|Debug8|Resip|>>:ClientAuthManager::RealmState::addAuthentication, proxy: 0 Digest username="XXXXXXXXXX",realm="BroadWorks",nonce="BroadWorksXf4vl2ouiTbpvem0BW",uri="sip:
[email protected]:5060",response="c9b2c48073d67316530ad369befa5dbf",cnonce="0f3a7c415329b577",nc=00000001,qop=auth,algorithm=MD5
11:38:33.564|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: INVITE sip:
Via: SIP/2.0/ ;branch=z9hG4bK-d87543-8e4d8e28c765d964-1--d87543-;rport
Max-Forwards: 70
Contact: <sip:
To: "XXXXXXX"<sip:
CSeq: 2 INVITE
Authorization: Digest username="XXXXXXXXXX",realm="BroadWorks",nonce="BroadWorksXf4vl2ouiTbpvem0BW",uri="sip:
Content-Length: 246
v=0
s=3cxPS Audio call
t=0 0
a=rtpmap:3 GSM/8000
11:38:33.564|DialogId.cxx(50)|Debug8|Resip|>>
ialogId:
11:38:33.564|DialogUsageManager.cxx(912)|Debug8|Resip|>>:Using outbound proxy: sip:
[email protected]:5060 tid=8e4d8e28c765d964 cseq=INVITE
[email protected]:5060 / 2 from(tu)
11:38:33.664|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer B tid=8e4d8e28c765d964 ms=32000
11:38:33.664|DnsResult.cxx(186)|Debug8|Resip|>>
11:38:33.664|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer A tid=8e4d8e28c765d964 ms=500
11:38:33.664|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 147.135.12.221:5060 UDP target domain=sip.broadvoice.com connectionId=0 ] -> [ V4 xxx.xxx.xxx.xxx:0 UDP target domain=sip.broadvoice.com connectionId=0 ] sent-by= sent-port=0
11:38:33.664|TransportSelector.cxx(971)|Debug8|Resip|>>:findTransportBySource([ V4 xxx.xxx.xxx.xxx:0 UDP target domain=sip.broadvoice.com connectionId=0 ])
11:38:33.664|TransportSelector.cxx(1083)|Debug8|Resip|>>:findTransport (any port, any interface) => Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ]
11:38:33.664|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 147.135.12.221:5060 UDP target domain=sip.broadvoice.com received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=sip.broadvoice.com connectionId=0 ]INVITE sip:
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK-d87543-8e4d8e28c765d964-1--d87543-;rport
Max-Forwards: 70
Contact: <sip:
To: "XXXXXXX"<sip:
CSeq: 2 INVITE
Content-Length: 246
v=0
s=3cxPS Audio call
t=0 0
a=rtpmap:3 GSM/8000
11:38:33.664|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 147.135.12.221:5060 UDP target domain=sip.broadvoice.com received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:33.725|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 147.135.12.221:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:33.725|DnsResult.cxx(177)|Debug8|Resip|>>:Whitelisting sip.broadvoice.com(1): 147.135.12.221
11:38:33.725|dns\RRVip.cxx(129)|Debug8|Resip|>>:updating an existing vip: 147.135.12.221 with 147.135.12.221
11:38:33.725|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 SIP/2.0 100 Trying
Via: SIP/2.0/UDP xxx.xxx.xxx.xxx:5060;branch=z9hG4bK-d87543-8e4d8e28c765d964-1--d87543-;received=xxx.xxx.xxx.xxx;rport=5060
To: "XXXXXXX"<sip:
[email protected]>
CSeq: 2 INVITE
Content-Length: 0
11:38:33.725|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 100 tid=8e4d8e28c765d964 cseq=INVITE / 2 from(wire)
11:38:33.725|DialogUsageManager.cxx(1646)|Debug8|Resip|>>
ialogUsageManager:
rocessResponse: SipResp: 100 tid=8e4d8e28c765d964 cseq=INVITE / 2 from(wire)
11:38:37.139|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 147.135.12.221:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:37.139|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 SIP/2.0 180 Ringing
Contact: <sip:
[email protected]>
To: "XXXXXXX"<sip:
[email protected]>;tag=1234
CSeq: 2 INVITE
Content-Length: 0
11:38:37.139|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 180 tid=8e4d8e28c765d964 cseq=INVITE
11:38:37.139|DialogUsageManager.cxx(1646)|Debug8|Resip|>>
ialogUsageManager:
rocessResponse: SipResp: 180 tid=8e4d8e28c765d964 cseq=INVITE
11:38:37.139|ClientAuthManager.cxx(41)|Debug8|Resip|>>:ClientAuthManager::handle: transitioning ZjFkNjBlOWFkYTQzZjNiN2M2NTJmNzhjZWU0YmNlYWM.-7758bb08to cached
11:38:37.139|ClientAuthManager.cxx(193)|Debug8|Resip|>>:ClientAuthManager::RealmState::transition from current to cached
11:38:37.139|DialogId.cxx(50)|Debug8|Resip|>>
ialogId:
ialogId: ZjFkNjBlOWFkYTQzZjNiN2M2NTJmNzhjZWU0YmNlYWM.-7758bb08-1234
11:38:37.139|DialogSet.cxx(717)|Debug8|Resip|>>:Creating a new Dialog from msg: SIP/2.0 180 Ringing
Contact: <sip:
[email protected]>
To: "XXXXXXX"<sip:
CSeq: 2 INVITE
Content-Length: 0
ialogId:
11:38:37.139|Dialog.cxx(205)|Debug8|Resip|>>:************** Created Dialog as UAC **************
11:38:37.139|Dialog.cxx(206)|Debug8|Resip|>>:mRemoteNameAddr: "XXXXXXX"<sip:
11:38:37.139|Dialog.cxx(207)|Debug8|Resip|>>:mLocalNameAddr: "EasyDesk, LLC"<sip:
11:38:37.139|Dialog.cxx(208)|Debug8|Resip|>>:mLocalContact: <sip:
11:38:37.139|Dialog.cxx(209)|Debug8|Resip|>>:mRemoteTarget: <sip:
[email protected]>
11:38:37.139|Dialog.cxx(214)|Debug8|Resip|>>
ialog:
ialog ZjFkNjBlOWFkYTQzZjNiN2M2NTJmNzhjZWU0YmNlYWM.-7758bb08-1234
11:38:37.139|DialogSet.cxx(755)|Debug8|Resip|>>:### Calling CreateAppDialog ### SIP/2.0 180 Ringing
Contact: <sip:
[email protected]>
To: "XXXXXXX"<sip:
CSeq: 2 INVITE
Content-Length: 0
11:38:37.139|Dialog.cxx(300)|Debug8|Resip|>>
ialog::dispatch: SipResp: 180 tid=8e4d8e28c765d964 cseq=INVITE
11:38:37.139|KeepAliveManager.cxx(40)|Debug8|Resip|>>:Association added for [ V4 147.135.12.221:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:37.139|Dialog.cxx(547)|Trace5|Resip|>>
ialog::dispatch, ignoring stray response: SipResp: 180 tid=8e4d8e28c765d964 cseq=INVITE
11:38:37.139|Dialog.cxx(567)|Debug8|Resip|>>
ialog::dispatch -- Created new client invite sessionSipResp: 180 tid=8e4d8e28c765d964 cseq=INVITE
11:38:37.139|InviteSession.cxx(73)|Debug8|Resip|>>:^^^ InviteSession::InviteSession 017DC590
11:38:37.139|Helper.cxx(1907)|Debug8|Resip|>>:No sdp
11:38:37.139|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAC_Start -> UAC_Early
11:38:37.139|.\ISHandler.cpp(31)|Trace5|CallControl|ISHandler:
nNewSession:Answered: sis=7608;oat=None;rl=SIP/2.0 180 Ringing
11:38:37.139|.\CallStrategies.cpp(598)|Trace5|CallManager|StratInOut:
nAnswered:Call from Ext.211 is answered on Ln:10001@BroadVoice 2
11:38:37.139|.\CallTarget.cpp(452)|Trace5|CallManager|CT_Lines::answered:Call is accepted on 10001@L:2@C:1a
11:38:37.139|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Ringing; DN 10001
11:38:37.139|ClientInviteSession.cxx(315)|Trace5|Resip|>>:UAC_Early: startStaleCallTimer
11:38:37.139|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: DumTimeout::StaleCall INVITE: 7608 UAC_Early ADDR="EasyDesk, LLC"<sip:
[email protected]>;tag=7758bb08 PEER="XXXXXXX"<sip:
[email protected]>;tag=1234: duration=194 seq=2
11:38:37.139|.\ISHandler.cpp(57)|Trace5|CallControl|ISHandler:
nProvisional
rovisional: cis=7608;rl=SIP/2.0 180 Ringing
11:38:37.139|.\Call.cpp(212)|Message5|CallControl|CallLegImpl:
nProvisional:Leg.onProv. 10001@L:2@C:1a got:
SIP/2.0 180 Ringing
Contact: <sip:
[email protected]>
To: "XXXXXXX"<sip:
CSeq: 2 INVITE
Content-Length: 0
11:38:37.139|.\CallConf.cpp(178)|Log2|CallControl|CallConf:
nProvisional:[CM103003] Call(26): Ln:10001@BroadVoice 2 is ringing
11:38:37.139|.\CallStrategies.cpp(658)|Trace5|CallManager|StratInOut:
nProvisional:InOut: got provisional SIP/2.0 180 Ringing from 10001@L:2@C:1a
11:38:37.139|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Calling; DN 211
11:38:37.139|ServerInviteSession.cxx(91)|Trace5|Resip|>>:UAS_EarlyOffer: provisional(180)
11:38:37.139|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_EarlyOffer -> UAS_EarlyOffer
11:38:37.139|Helper.cxx(302)|Debug8|Resip|>>:Helper::makeResponse(SipReq: INVITE
[email protected] / 2 from(wire) code=180 reason=
11:38:37.139|Dialog.cxx(970)|Debug8|Resip|>>
ialog::makeResponse: SIP/2.0 180 Ringing
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 0
11:38:37.139|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: DumTimeout::Retransmit1xx INVITE: 7605 UAS_EarlyOffer ADDR=<sip:
11:38:37.139|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler:
nReadyToSend:InviteSession(7605) sends SIP/2.0 180 Ringing
11:38:37.139|.\ISHandler.cpp(141)|Message5|CallControl|ISHandler:
SIP/2.0 180 Ringing
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 0
11:38:37.139|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: SIP/2.0 180 Ringing
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 0
11:38:37.139|SipStack.cxx(278)|Debug8|Resip|>>:SEND: SipResp: 180 tid=c196bc9d2884D7C4 cseq=INVITE
11:38:37.239|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 xxx.xxx.xxx.xxx:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by=xxx.xxx.xxx.xxx sent-port=0
11:38:37.239|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]SIP/2.0 180 Ringing
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Content-Length: 0
11:38:37.239|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:41.344|KeepAliveManager.cxx(67)|Debug8|Resip|>>:Refreshing keepalive for [ V4 147.135.12.221:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:41.344|KeepAliveManager.cxx(68)|Debug8|Resip|>>:Keepalive interval 30 seconds
11:38:41.344|KeepAliveManager.cxx(69)|Debug8|Resip|>>:Keepalive id 0)
11:38:41.344|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 147.135.12.221:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](0)
11:38:41.344|KeepAliveManager.cxx(67)|Debug8|Resip|>>:Refreshing keepalive for [ V4 64.2.142.30:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:41.344|KeepAliveManager.cxx(69)|Debug8|Resip|>>:Keepalive id 1)
11:38:41.344|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 64.2.142.30:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](1)
11:38:41.445|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 147.135.12.221:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 xxx.xxx.xxx.xxx:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by= sent-port=0
11:38:41.445|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 147.135.12.221:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:41.445|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 147.135.12.221:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:41.445|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 64.2.142.30:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 xxx.xxx.xxx.xxx:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by= sent-port=0
11:38:41.445|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 64.2.142.30:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 xxx.xxx.xxx.xxx:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:41.445|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 64.2.142.30:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
11:38:47.352|ClientRegistration.cxx(234)|Trace5|Resip|>>:requesting refresh of ClientRegistration sip:
[email protected]
11:38:47.352|ClientAuthManager.cxx(313)|Debug8|Resip|>>: Add auth, 01787620 in response to: DIGEST realm="BroadWorks",qop="auth",algorithm=MD5,nonce="BroadWorksXf4uny1z8Tjuok9wBW"
11:38:47.352|Helper.cxx(1125)|Debug8|Resip|>>:nonceCount is now: [00000897]
11:38:47.352|ClientAuthManager.cxx(321)|Debug8|Resip|>>:ClientAuthManager::RealmState::addAuthentication, proxy: 0 Digest username="XXXXXXXXXX",realm="BroadWorks",nonce="BroadWorksXf4uny1z8Tjuok9wBW",uri="sip:sip.broadvoice.com",response="dd66b6d9cd388bf48cf053dcf546352f",cnonce="9f225e540a4f9f1d",nc=00000897,qop=auth,algorithm=MD5
11:38:47.352|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: REGISTER sip:sip.broadvoice.com SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d87543-c10a2f67ef163b41-1--d87543-;rport
Max-Forwards: 70
