Random RTP Loss Issues....
Discussion in '3CX Phone System - General' started by Tularis, Oct 13, 2010.
  1. Tularis
    Apr 12, 2010
    16
    I have had 3cx installed and configured for a few months now and everything seems to be working correctly.
    But every so often a call will come through and I will not be able to hear any audio, some times a call will come in and the client will also not be able to hear any audio.
    I believe this is due to this statement in the error log...
    12:28:50.406 [MS105000] C:106.1: No RTP packets were received:remoteAddr=91.xxx.xxx.xxx:57302,extAddr=92.xxx.xxx.xxx:9016,localAddr=92.xxx.xxx.xxx:9016
    The RTP Ports are configured to be 9000 - 9049
    These Ports have been opened on the router on the exact same range.
    The router is a "Netgear DGN1000" I have tried the setting "Disable SIP ALG" in the router options but it doesn't make any difference.
    If the ports are open, and most of the time we can hear audio BOTH WAYS then what could be blocking it randomly?
    Apologies if I have missed something very basic, 3cx is still quite new to me...
    <Edit>
    3CX Firewall Check Passes Perfectly:
    Code:
    3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
    <12:56:50>: Phase 1, checking servers connection, please wait...
    <12:56:50>: Stun Checker service is reachable. Phase 1 check passed.
    <12:56:50>: Phase 2a,  Check Port Forwarding to UDP SIP port, please wait...
    <12:56:51>: UDP SIP Port is set to 5060. Response received correctly with no translation. Phase 2a check passed.
    <12:56:51>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
    <12:56:51>: TCP SIP Port is set to 5060. Response received correctly with no translation. Phase 2b check passed.
    <12:56:51>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
    <12:56:51>: TCP TUNNEL Port is set to 5090. Response received correctly with no translation. Phase 3 check passed.
    <12:56:51>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
    <12:56:57>: UDP RTP Port 9000. Response received correctly with no translation. Phase 4-01 check passed.
    <12:56:57>: UDP RTP Port 9001. Response received correctly with no translation. Phase 4-02 check passed.
    <12:56:57>: UDP RTP Port 9002. Response received correctly with no translation. Phase 4-03 check passed.
    <12:56:57>: UDP RTP Port 9003. Response received correctly with no translation. Phase 4-04 check passed.
    <12:56:57>: UDP RTP Port 9004. Response received correctly with no translation. Phase 4-05 check passed.
    <12:56:57>: UDP RTP Port 9005. Response received correctly with no translation. Phase 4-06 check passed.
    <12:56:57>: UDP RTP Port 9006. Response received correctly with no translation. Phase 4-07 check passed.
    <12:56:57>: UDP RTP Port 9007. Response received correctly with no translation. Phase 4-08 check passed.
    <12:56:58>: UDP RTP Port 9008. Response received correctly with no translation. Phase 4-09 check passed.
    <12:56:58>: UDP RTP Port 9009. Response received correctly with no translation. Phase 4-10 check passed.
    <12:56:58>: UDP RTP Port 9010. Response received correctly with no translation. Phase 4-11 check passed.
    <12:56:58>: UDP RTP Port 9011. Response received correctly with no translation. Phase 4-12 check passed.
    <12:56:58>: UDP RTP Port 9012. Response received correctly with no translation. Phase 4-13 check passed.
    <12:56:58>: UDP RTP Port 9013. Response received correctly with no translation. Phase 4-14 check passed.
    <12:56:58>: UDP RTP Port 9014. Response received correctly with no translation. Phase 4-15 check passed.
    <12:56:58>: UDP RTP Port 9015. Response received correctly with no translation. Phase 4-16 check passed.
    <12:56:58>: UDP RTP Port 9016. Response received correctly with no translation. Phase 4-17 check passed.
    <12:56:58>: UDP RTP Port 9017. Response received correctly with no translation. Phase 4-18 check passed.
    <12:56:59>: UDP RTP Port 9018. Response received correctly with no translation. Phase 4-19 check passed.
    <12:56:59>: UDP RTP Port 9019. Response received correctly with no translation. Phase 4-20 check passed.
    <12:56:59>: UDP RTP Port 9020. Response received correctly with no translation. Phase 4-21 check passed.
    <12:56:59>: UDP RTP Port 9021. Response received correctly with no translation. Phase 4-22 check passed.
    <12:56:59>: UDP RTP Port 9022. Response received correctly with no translation. Phase 4-23 check passed.
    <12:56:59>: UDP RTP Port 9023. Response received correctly with no translation. Phase 4-24 check passed.
    <12:56:59>: UDP RTP Port 9024. Response received correctly with no translation. Phase 4-25 check passed.
    <12:56:59>: UDP RTP Port 9025. Response received correctly with no translation. Phase 4-26 check passed.
    <12:56:59>: UDP RTP Port 9026. Response received correctly with no translation. Phase 4-27 check passed.
    <12:56:59>: UDP RTP Port 9027. Response received correctly with no translation. Phase 4-28 check passed.
    <12:57:00>: UDP RTP Port 9028. Response received correctly with no translation. Phase 4-29 check passed.
    <12:57:00>: UDP RTP Port 9029. Response received correctly with no translation. Phase 4-30 check passed.
    <12:57:00>: UDP RTP Port 9030. Response received correctly with no translation. Phase 4-31 check passed.
    <12:57:00>: UDP RTP Port 9031. Response received correctly with no translation. Phase 4-32 check passed.
    <12:57:00>: UDP RTP Port 9032. Response received correctly with no translation. Phase 4-33 check passed.
    <12:57:00>: UDP RTP Port 9033. Response received correctly with no translation. Phase 4-34 check passed.
    <12:57:00>: UDP RTP Port 9034. Response received correctly with no translation. Phase 4-35 check passed.
    <12:57:00>: UDP RTP Port 9035. Response received correctly with no translation. Phase 4-36 check passed.
    <12:57:00>: UDP RTP Port 9036. Response received correctly with no translation. Phase 4-37 check passed.
    <12:57:00>: UDP RTP Port 9037. Response received correctly with no translation. Phase 4-38 check passed.
    <12:57:01>: UDP RTP Port 9038. Response received correctly with no translation. Phase 4-39 check passed.
    <12:57:01>: UDP RTP Port 9039. Response received correctly with no translation. Phase 4-40 check passed.
    <12:57:01>: UDP RTP Port 9040. Response received correctly with no translation. Phase 4-41 check passed.
    <12:57:01>: UDP RTP Port 9041. Response received correctly with no translation. Phase 4-42 check passed.
    <12:57:01>: UDP RTP Port 9042. Response received correctly with no translation. Phase 4-43 check passed.
    <12:57:01>: UDP RTP Port 9043. Response received correctly with no translation. Phase 4-44 check passed.
    <12:57:01>: UDP RTP Port 9044. Response received correctly with no translation. Phase 4-45 check passed.
    <12:57:01>: UDP RTP Port 9045. Response received correctly with no translation. Phase 4-46 check passed.
    <12:57:01>: UDP RTP Port 9046. Response received correctly with no translation. Phase 4-47 check passed.
    <12:57:01>: UDP RTP Port 9047. Response received correctly with no translation. Phase 4-48 check passed.
    <12:57:02>: UDP RTP Port 9048. Response received correctly with no translation. Phase 4-49 check passed.
    <12:57:02>: UDP RTP Port 9049. Response received correctly with no translation. Phase 4-50 check passed.
    Application exit code is 0
  2. Tularis
    Apr 12, 2010
    16
    Bump!
    Ok so we have worked out that this seems to be localised to any callers calling in from not BT provisioned lines.
    Does anyone have any information or advice on things I could try to figure out why certain calls only get one-way audio?
    The only thing that seems to make any relevance is the " No RTP packets were received " entry in the log, but if it was RTP related then surly this would effect "ALL" calls.?!
