Randomising Music On Hold
Discussion in '3CX Phone System - General' started by ahmed24, Aug 1, 2016.
  1. ahmed24
    Mar 29, 2016
    23
    I have different music on hold tracks which has embedded on hold message each. Rather than joining them all into one file, I thought if i keep them as different files then have them play in different orders. When I did this and uploaded the multiple tracks and selected randomize, it just randomly selects a file and just repeats that file.
    Problem with putting all the on hold messages inside the on hold track is that the on hold messages will always be in the same order. Unless I make it all one track and have it in different orders as different files.
    Any ideas?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    If not mistaken, I believe that the MOH is random when initially selecting the file. I do not think that the system goes on to select other files similar to a "play list" manner once the initial file has reached the end, but rather that it loops the selected file for the duration of the on-hold period for that call. Should another call come in while the original call is still holding, the system will then select a file for that caller which may or may not be the same.
