Raspberry Pi 2 with 3CX
Discussion in '3CX Phone System - General' started by millennium2, Mar 2, 2015.
  1. millennium2
    Apr 8, 2011
    57
    Is the 3CX Session Border Controller compatible with the new "Raspberry Pi 2"? And if so, how many remote phones behind it does it support?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    You can install SBC package on raspberry pi 2 and it will run but the current build will not take advantage of the 4 cores / multithreading possible with this new device.
    Please wait for new announcements on this matter.
