Solved Raspberry Pi 3 SBC wont work after reboot
Discussion in '3CX Phone System - General' started by OCWI, Jan 17, 2017.
  1. OCWI
    OCWI New Member
    Jan 17, 2017
    159
    44
    I am trying to put raspberry pi 3's in the field as SBC's / border session controllers and things work when install the sbc right away, but then after rebooting it stops working!!!!
    I know little to nothing about linux, which im sure doesnt help...
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @OCWI
    This could be because after a restart the SBC service does not start as the network is not ready. Try setting the network boot at delayed start and see if that solves your issue.
    To do so log into the terminal and type
    sudo raspi-config
    select: Wait for network at boot and then: Slow wait for network connection before completing boot
    click ok and finish and restart the Raspberry Pi
    sudo shutdown -r now
    OCWI likes this.
  3. Peter Richardson
    Peter Richardson New Member
    Apr 6, 2017
    149
    5
    Hey @YiannisH_3CX
    Thanks very much for this tip, I've just had the same problem and this solved it! So easy!
  4. OCWI
    OCWI New Member
    Jan 17, 2017
    159
    44
    THIS WORKED!!! THANK YOU SO MUCH!
  5. Peter Richardson
    Apr 6, 2017
    149
    5
    Wait wait wait a minute! Okay, so we've had some great success to get this to work...initially. However, if you were to unplug the network cable, reboot the switch, reboot the router, or make any other network change, then it just doesn't work. The phones become unreachable and then are unable to connect to the SBC again. I believe that it's got something to do with the SBC not restarting the 3CX service again, because the only way to fix it is to reboot the SBC. But I can't have this as a normal part of troubleshooting as I have located the router, switches, SBC in a network cabinet that is very difficult to get into as it has about 15 devices in it, so instructing the customer to "just unplug and replug the Raspberry Pi" would require them to know what they were doing, and this customer has a hard time using the phone, let alone identifying network equipment. Please help!
    myuniquename likes this.
  6. Peter Richardson
    Apr 6, 2017
    149
    5
  7. computatech
    Oct 21, 2016
    20
    Thanks that has worked for me too! ;)
  8. Peter Richardson
    Apr 6, 2017
    149
    5
    Can someone please help? This customer had a power outage yesterday and I am guessing that the router or switch took longer to boot than the raspberry pi, and thus I had to go through a lengthy process over the phone of talking the customer through identifying, unplugging then replugging the raspberry pi. Not good.
    Please help!
  9. OCWI
    OCWI New Member
    Jan 17, 2017
    159
    44
    I think the best course of action here is to have 3cx further refine the BSC software.
    In the meantime we started putting the rasp pi's on dataplicity so we can access the terminal and more importantly do a remote reboot.
    There are a few solutions along these lines, looked at VNC and another remote control item before settling on dataplicity. I like dataplicity because myself and all my techs can control the pi's easily from our cell phones and see when they are up/down.
    They however arent very cheap, at $2/mo/pi. Not impressed with that but not many options out there.
    On this note, is there any intention from 3cx to further refine the BSC software? I love how often the PBX software is updated and the new features always being introduced, but in the time we have resold them (about a year now) we never really saw any sort of real updates for the BSC software linux or otherwise.
  10. Peter Richardson
    Apr 6, 2017
    149
    5
    Hey @OCWI
    This is genius! I'll check that out.
    Agreed, 3CX needs to look into this fundamental flaw. Anyone else had this problem?
  11. OCWI
    OCWI New Member
    Jan 17, 2017
    159
    44
    Actually on second thought that statement wasn't totally fair to 3cx. We have seen some rather significant SBC improvement over the last year particularly with regard to the raspberry pi. I hope it continues in that direction and maybe even a little more focus on it!
    It would be really nice to have some sort of tunnel uptime monitoring, or even a tunnel up/down status in the PBX!
  12. Peter Richardson
    Apr 6, 2017
    149
    5
    how do we remove the "solved" from this thread?
  13. OCWI
    OCWI New Member
    Jan 17, 2017
    159
    44
    I think an admin has to do that...
  14. Peter Richardson
    Apr 6, 2017
    149
    5
    bump! Someone please help!
  15. Peter Richardson
    Apr 6, 2017
    149
    5
  16. YiannisH_3CX
    May 10, 2016
    4,349
    274
    If you want something implemented regarding the SBC functionality or software then you should create a feature request in the ideas section of the forum where users can upvote these ideas and then the appropriate departments can review them.
  17. Peter Richardson
    Apr 6, 2017
    149
    5
    @YiannisH_3CX
    Wait wait wait a minute! Okay, so we've had some great success to get this to work...initially. However, if you were to unplug the network cable, reboot the switch, reboot the router, or make any other network change, then it just doesn't work. The phones become unreachable and then are unable to connect to the SBC again. I believe that it's got something to do with the SBC not restarting the 3CX service again, because the only way to fix it is to reboot the SBC. But I can't have this as a normal part of troubleshooting as I have located the router, switches, SBC in a network cabinet that is very difficult to get into as it has about 15 devices in it, so instructing the customer to "just unplug and replug the Raspberry Pi" would require them to know what they were doing, and this customer has a hard time using the phone, let aloneidentifying network equipment. Please help!
    Please help!
  18. OCWI
    OCWI New Member
    Jan 17, 2017
    159
    44
    reterex likes this.
  19. reterex
    Jul 12, 2017
    Peter Richardson likes this.
