RATING OUT BOUND CALLS
Discussion in '3CX Phone System - General' started by alex weber, Jun 6, 2011.
  1. alex weber
    Jun 20, 2010
    ne very important feature that most of the companies need is:
    1. option to rate calls and see the usage of any employee
    2. option to reroute calls if one route fails
    lock-picking
    Your product is very nice and coming from asterisks background it is made for any one
    kind regards
  2. willow
    willow Member
    Mar 1, 2011
    471
    it already does these things.
    there is already a cdr program for call details and there is a default costing system for calls.
    there are 3 routes possible for a call in an outbound rule. if the route is unavailable it should fail to the second.
  3. jpmardini
    Jun 21, 2011
    Is there an EASY way to export the CDR records and billing totals into a MySQL database for storage?
    I'm a 3CX newbie :roll:
    Thanks,
    John M.
  4. jpmardini
    Jun 21, 2011
    That's great! Thanks for the response.
    Do you know of any way that 3CX can automatically send everything into the MySQL database say daily, hourly, etc?
    Thanks!
