RC2 = final relase?**OK
Discussion in '3CX Phone System - General' started by sunstate, May 12, 2011.
  1. sunstate
    sunstate Member
    Dec 16, 2009
    257
    I noticed the blog post earlier anouncing v10, so I downloaded and installed it thinking it was the final build. Well it's got the same build number as RC2. So is RC2 the actual release version?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    Re: RC2 = final relase?
    Yes RC2 is the final. We got a lot of good feedback overall and decided to make it final and soon we will have a service pack.
