RC2 not working with CallCentric?
Discussion in '3CX Phone System - General' started by VirtualMIS, Jun 11, 2008.
  1. VirtualMIS
    Jun 9, 2008
    41
    I am evaluating 6.0 RC1 and have a connection to CallCentric setup. The provider entry registers OK but when I try to make and outgoing call I get a "403 User does not exist" error. I have connected to CallCentric using X-Lite without a problem. Did something get changed in the 6.0 release that broke the standard CallCentric setup template?
    Matt
  2. ftdevon
    Jun 11, 2008
    I had a similar issue with Callcentric setup. I went ahead and followed the setup that is posted on callcentrics website for the 3cx pbx using the generic voip provider and everything works fine. The only difference is I chose External (STUn resolved) for registration settings)
  3. VirtualMIS
    Jun 9, 2008
    41
    Thanks for the reply. I tried the CallCentric supplied config instructions too and tried both External and Internal IP for the contact field. Still no luck.
    I turned verbose logging on and this is what I get... Interesting that the outbound call fails because "User does not exist" but prior to that the Registration with CallCentric succeeds. Registration would not succeed if the user account really did not exist. ???
    19:39:32.923 Call::Terminate [CM503008]: Call(2): Call is terminated
    19:39:32.892 Call::RouteFailed [CM503015]: Call(2): Attempt to reach [sip:815031234567@192.168.168.3;user=phone] failed. Reason: Forbidden
    19:39:32.892 CallLeg::eek:nFailure [CM503003]: Call(2): Call to sip:15031234567@callcentric.com:5060 has failed; Cause: 403 User does not exist; from IP:204.11.192.34:5060
    19:39:32.142 MediaServerReporting::SetRemoteParty [MS210004] C:2.2:Offer provided. Connection(proxy mode): xxx.xxx.xxx.xxx:9000(9001)
    19:39:31.970 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(2): Calling: VoIPline:15031234567@(Ln.10000@CallCentric)@[Dev:sip:My_SIP_Login@callcentric.com:5060]
    19:39:31.970 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:815031234567@192.168.168.3;user=phone]
    19:39:31.970 MediaServerReporting::SetRemoteParty [MS210000] C:2.1:Offer received. RTP connection: 192.168.168.34:52676(52677)
    19:39:31.970 CallLeg::setRemoteSdp Remote SDP is set for legC:2.1
    19:39:31.970 Extension::printEndpointInfo [CM505001]: Ext.101: Device info: Device Identified: [Man: Snom;Mod: 320;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom320/7.1.30] Transport: [sip:192.168.168.3:5060]
    19:39:31.908 CallCtrl::eek:nIncomingCall [CM503001]: Call(2): Incoming call from Ext.101 to [sip:815031234567@192.168.168.3;user=phone]
    19:39:31.908 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:815031234567@192.168.168.3;user=phone SIP/2.0
    Via: SIP/2.0/UDP 192.168.168.34:2054;branch=z9hG4bK-mq07bxyva3nz;rport=2054
    Max-Forwards: 70
    Contact: [sip:101@192.168.168.34:2054];flow-id=1
    To: [sip:815031234567@192.168.168.3;user=phone]
    From: "Matt Miller"[sip:101@192.168.168.3];tag=ppsokyntvz
    Call-ID: 3c28f9d5e95f-xy1f2ho0lxr0
    CSeq: 2 INVITE
    Session-Expires: 3600;refresher=uas
    Min-SE: 90
    Accept: application/sdp
    Allow: INVITE, ACK, CANCEL, BYE, REFER, OPTIONS, NOTIFY, SUBSCRIBE, PRACK, MESSAGE, INFO
    Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="12857711969:938d6b60d66e8194581d491e1482c797",uri="sip:815031234567@192.168.168.3;user=phone",response="82319534534459a41eaa2985300497ed",algorithm=MD5
    Supported: timer, 100rel, replaces, callerid
    User-Agent: snom320/7.1.30
    Allow-Events: talk, hold, refer, call-info
    Content-Length: 0
    P-Key-Flags: keys="3"
    19:36:07.767 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.168.3:5060
    19:19:45.265 ClientRegs::eek:nSuccess [CM504004]: Registration succeeded for: 10000@CallCentric
    19:19:44.844 ClientRegs::Register [CM504003]: Sent registration request for 10000@CallCentric
  4. alexba254
    Jun 13, 2008
    I am also having this exact problem. When I spoke with CallCentric Support they told me to rollback to version 3. I am using the free edition of v. 5. Any solutions?
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,888
    190
    Its best to use v6 - its been tested with Callcentric and known to work. If you still need help, you can open a support issue with 3CX (requires a support account)
  6. raldridge
    Jun 6, 2008
    21
    I'm using the latest beta of version 6 and have tried everything and can't seem to get Callcentric to work. I don't even see in the logs where it tries to register.
    Anyone else having issues or has gotten it to work?
  7. Nick Galea
    Jun 6, 2006
    1,888
    190
    This works 100%, no doubts about it. You have a network/firewall/configuration issue....
  8. raldridge
    Jun 6, 2008
    21
    I would disagree somewhat as I just got it working by changing the registration IP to a static one instead of using internal. I also have removed all the STUN settings. This was the only way I could get it to register. I've opened up all the needed ports on the FW and used static NATing. But I couldn't find anywhere in the documentation that the STUN ports needed to be opened. Is this the case? And what STUN servers should be used?
  9. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    STUN ports should be opened only outbound. I mean your router should allow outbound traffic to port 3478.
    You can use any STUN server you like.
  10. raldridge
    Jun 6, 2008
    21
    Then these ports were open. What are the recommneded STUN servers for using 3CX or Callcentric?
  11. blee@futronics.us
    May 30, 2008
    I am having the same problems with version 5 and 6. Our company has a different vendors VOIP software and it does work with CallCentric so I don't think it is a CallCentric issue, matter a fact CallCentric is not seeing any calls coming from our 3CX server. Here is what my version 5 log is showing;
    17:02:30.479 Call::Terminate [CM503008]: Call(6): Call is terminated
    17:02:30.432 Call::RouteFailed [CM503014]: Call(6): Attempt to reach [sip:94193325111@10.5.1.16;user=phone] failed. Reason: Forbidden
    17:02:30.416 CallLeg::eek:nFailure [CM503003]: Call(6): Call to sip:14193325111@callcentric.com:5060 has failed; Cause: 403 User does not exist; from IP:204.11.192.23:5080
    17:02:30.041 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(6): Calling: VoIPline:10000@[Dev:sip:17772772197@callcentric.com:5060]
    17:02:29.979 CallCtrl::eek:nIncomingCall [CM503001]: Call(6): Incoming call from Ext.108 to [sip:94193325111@10.5.1.16;user=phone]
    17:01:52.338 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@10.5.1.16:5060 with contact sip:888@10.5.1.16:5100;user=phone
    17:01:51.447 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
    17:01:40.010 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 10.5.1.16:5060
    16:52:06.807 Call::Terminate [CM503008]: Call(5): Call is terminated
    16:52:06.760 Call::RouteFailed [CM503014]: Call(5): Attempt to reach [sip:94193325111@10.5.1.16;user=phone] failed. Reason: Forbidden
    16:52:06.744 CallLeg::eek:nFailure [CM503003]: Call(5): Call to sip:14193325111@callcentric.com:5060 has failed; Cause: 403 User does not exist; from IP:204.11.192.34:5080
    16:52:04.354 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(5): Calling: VoIPline:10000@[Dev:sip:17772772197@callcentric.com:5060]
    16:52:04.291 CallCtrl::eek:nIncomingCall [CM503001]: Call(5): Incoming call from Ext.108 to [sip:94193325111@10.5.1.16;user=phone]
    CallCentric did not recieve anything for either of these outbound calls. Does anyone have any ideas?
    I did download the latest updates for version 5 and 6 although I had the same results. I did verify that our firewall was confirgured correctly with the 3CX software. I have tried NATing for the STUN server, internal and external STUN servers which did not make a differance.
  12. raldridge
    Jun 6, 2008
    21
    I too can't make calls outbound with Callcentric and my logs are identical to yours when I try. I can receive inbound calls though on my DID number with Callcentric.
    I'm running the release version 6, but my firewall test always fails. I'm working on it now trying to best configure my Watchguard FW to allow it to work. Not having much luck.
  13. archie
    3CX Support
    Aug 18, 2006
    1,299
    Who has that IP?
  14. tigernet
    Apr 10, 2008
    12
    Also getting same error with CallCentric line
    [CM503003]: Call(1047): Call to sip:4193325111@callcentric.com:5060 has failed; Cause: 403 User does not exist; from IP:204.11.192.23:5080
    To answer your question Archie
    >nslookup callcentric.com
    Server: vcfx3.xxxx.local
    Address: 172.xx.xx.221
    Non-authoritative answer:
    Addresses: 204.11.192.34, 204.11.192.23
    thanks
    Tim
  15. archie
    3CX Support
    Aug 18, 2006
    1,299
    So, Callcentric has answered "403 User not found" and still claims it didn't get any requests. Isn't it strange?
  16. raldridge
    Jun 6, 2008
    21
    CallCentric support provided the fix for me and the only one I changed from the list below was:
    And that did the trick.
    First note that it seems 3CX version 5 and 6 beta are not properly configured to work with Callcentric by default. Please ensure that you are using the following settings under the “Gateway/Provider Outbound Parameters”:
    Request Line URI: User Part: CalledNum
    Request Line URI: Host Part: GWHostPort
    Contact: User Part: AuthID
    Contact: Host Part: ContactUrl
    To: Display Name: CalledName
    To: User Part: CalledNum
    To: Host Part: GwHostPort
  17. archie
    3CX Support
    Aug 18, 2006
    1,299
    Actually, From: User Part: AuthID IS by-default setting. I will doublecheck it though.
    Just out of curiosity you can try to make it blank (defalut is applied then).
  18. raldridge
    Jun 6, 2008
    21
    On my stock CallCentric profile in the 3CX software, the default was "CallerName".
  19. archie
    3CX Support
    Aug 18, 2006
    1,299
    Oops, than it is definitely bug in template. Will be fixed.
  20. raldridge
    Jun 6, 2008
    21
    I also found I couldn't get Callcentric to register unless I used a specific IP address under registration. The template has it set at STUN which Callcentric tells me they don't support, and they recommended internal, which also didn't work for me.
