Solved Re-activating Licence
Discussion in '3CX Phone System - General' started by techdummy, Oct 2, 2017.
  1. techdummy
    techdummy New Member
    Sep 22, 2017
    202
    9
    I have changed the 3cx 12.5v into a Free Version so that i could take a backup that doesn't have Licence Key included.
    I need to "Activate" 3cx with the Licence Key again.
    What all details do I need to do this?
    What I mean is what are the mandatory details that are needed.
    Thanks.
  2. Archie Frederic
    Jan 31, 2017
    72
    What do you mean? Are you going to reinstall 3cx? are you going to upgrade from version 12.5 to version 15.5? or do you want to unbind your license key to your FQDN? Could you kindly elaborate it.
  3. techdummy
    Sep 22, 2017
    202
    9
    @Archie Frederic I'm just trying to re-activate the license on the same version. V12.5
    I just wanted to get a backup without the License Key and hence changed 3cx to free version. Now I want to revert it to the Licensed version it has always been. I don't want to make any changes.
    Do I just click on the "Activate" button or is there any need to provide the License Key and other details?
  4. techdummy
    Sep 22, 2017
    202
    9
    But yes, I have plans to upgrade from 12.5 to 15.5 and it is the reason why I had to take the backup without the License Key, to see what all changes happens when we restore the backup on 15.5.
    I'm doing a test run..but as for now, I just want to re-activate 12.5 with the same Licence Key.
  5. Archie Frederic
    Jan 31, 2017
    72
    if you're in version 12.5 you do not need to make everything complicated. your backup would not include your license key. All you need to do is to unbind your license key on your FQDN to be able to use your FQDN again or use the license key on another FQDN. License key and FQDN is only included in version 15 as an option. In lower version this is not included as a backup option.
  6. Archie Frederic
    Jan 31, 2017
    72
    By the way, you can unbind your license key to your FQDN through your customer portal.
  7. techdummy
    Sep 22, 2017
    202
    9
    I have gone ahead and provided all the details while re-activating the Key.
    All good.
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,326
    448
    Glad the issue is resolved
