Re: Incoming display incorrect
mfm
In regards to the 3102 there is a know issue, please see step 22 bottom note.
http:/ /www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE
Which states:
Note that in some geographical areas, this may cause incoming calls to fail, because the device incorrectly interprets the CallerID format. If this is the case, you may need to disable CallerID parsing by setting this field to empty.
This is a linksys issue and thus it out of the hands of 3CX when a fix for this will be available.
Get 3CX - Absolutely Free!
3CX
