re run install wizard
Discussion in '3CX Phone System - General' started by next2, Sep 19, 2017.
Tags:
  1. next2
    Apr 19, 2009
    22
    On a Debian install (ISO downloaded from 3cx website), is it possible to re-run the configuration wizard (http://ipbx_address:5015) without reinstalling the whole thing ?
    We probably made a mistake and would like to restart the initial configuration.
    Thank you !
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    Don't if it will work, but you can give it a try.
    sudo /usr/sbin/3CXWizard --cleanup
