Read file and play prompt
Discussion in 'Call Flow Designer' started by Rob24h, Jan 7, 2018.
  1. Rob24h
    Mar 20, 2017
    85
    6
    I just started with the CFD and I like it!
    I already made a project to write a value to a file on the server and this works fine. The problem I'm facing now is with the project to read the file contents and play an audiofile.
    This is my project:
    [​IMG]
    Reading the file goes fine. When I check the queuelog I can see it returns the correct value (the value can only be: 1, 2 or 3).
    Now what I want is an audio file to be played belonging to the returned value. So if readMyfile returns 1 I want to play PromptPlayback1 etc. This does not seem to work.
    For conditionalComponentBranch1 I have the condition: EQUAL(readMyFile.Result,"1") and so on for conditionalComponentBranch2 and conditionalComponentBranch3.
    The queuelog is not showing any errors:
    18/01/07 19:15:52.844|100049| Trc|75|0015|: PlugIn[uitlezenbestand - FileManagementComponent - CallID TXHRLFRKBZQO] Trace: End executing component - eofReached='True' - result: 2
    18/01/07 19:15:52.846|100049| Trc|75|0015|: PlugIn[uitlezenbestand - Callflow - MainFlow - CallID TXHRLFRKBZQO] Trace: Start executing component 'Logger1'
    18/01/07 19:15:52.848|100049| Trc|75|0015|: PlugIn[uitlezenbestand - LoggerComponent - CallID TXHRLFRKBZQO] Trace: 2
    18/01/07 19:15:52.850|100049| Trc|75|0015|: PlugIn[uitlezenbestand - Callflow - MainFlow - CallID TXHRLFRKBZQO] Trace: Start executing component 'Condition1'
    18/01/07 19:15:52.853|100049| Trc|75|0015|: PlugIn[uitlezenbestand - Callflow - MainFlow - CallID TXHRLFRKBZQO] Trace: Start executing component 'DisconnectCall1'
    What am I doing wrong?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,598
    125
    Hi @Rob24h,
    I think that the problem could be that the readMyFile component is reading some not visible character, like a space, a new line character, etc. I would try trimming the returned value, using the following expression:
    EQUAL(TRIM(readMyFile.Result),"1")
    Please give it a try.
    Kind regards.
  3. Rob24h
    Mar 20, 2017
    85
    6
    Even though there were no spaces in the txt file your solutions works perfect :)
    Thank you!
  4. edossantos
    Jun 27, 2007
    1,598
    125
    Hi @Rob24h,
    Maybe there were no spaces, but the component might read a final new line character, at the end of the line, and that made the difference.
    Kind regards.
    Ernesto.
