read logfile help
Discussion in '3CX Phone System - General' started by cfive, Apr 28, 2010.
  1. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    I could use a lesson in reading logfiles ;-). My customers customer complained, and said he called in after hours and the phone rang and rang and he got nothing. Twice. I have his calls here, and it looks like he got more than nothing, but I'm not quite sure what keys he pressed or didn't press.
    There are two calls, if someone can take the time to put them in plain language for me, I think I could do it next time!.
    Thanks, Les.
    10000 is the incoming trunk
    120 is the "system" extention that routes calls for time of day
    808 is a night service menu, with a 15 second repeat time-out
    999 is well known ;-)
    116 is an extension that goes straight to a voicemail
    What I'm not sure of is what keys the customer pressed (or didn't) to get to where he got. He didn't leave a voicemail.
    Code:
    1,20100428005056.002,de3e246ef868ae78,10000,120,4830258,anonymous,1
    3,20100428005056.002,de3e246ef868ae78,10000,4830258,4830258,,1
    9,20100428005056.002,de3e246ef868ae78,120,,,,1
    3,20100428005056.049,de3e246ef868ae78,808,,4830258,808,1
    2,20100428005056.205,de3e246ef868ae78,10000,808,4830258,120,1
    4,20100428005127.217,de3e246ef868ae78,10000,,4830258,,1
    4,20100428005127.217,de3e246ef868ae78,808,,808,,1
    6,20100428005127.420,de3e246ef868ae78,,,,,
    1,20100428005205.000,1d31db19e25d0720,10000,120,4830258,anonymous,1
    3,20100428005205.000,1d31db19e25d0720,10000,4830258,4830258,,1
    9,20100428005205.000,1d31db19e25d0720,120,,,,1
    3,20100428005205.047,1d31db19e25d0720,808,,4830258,808,1
    2,20100428005205.250,1d31db19e25d0720,10000,808,4830258,120,1
    3,20100428005239.320,1d31db19e25d0720,999,116,4830258,999,1
    4,20100428005239.694,1d31db19e25d0720,808,,808,,1
    4,20100428005243.950,1d31db19e25d0720,10000,,4830258,,1
    4,20100428005243.959,1d31db19e25d0720,999,,999,,1
    6,20100428005244.190,1d31db19e25d0720,,,,,
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Not sure where you fetched those logs from but we need the server logs if you want a brief explenation of what is going on.
  3. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    I would like to learn how to determine what's going on, so if you would be so kind to tell me which files to provide, I'll do so.
    The snipped part provided is from one of the logfiles, but I can't remember which one.
    Thanks, Les.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Were always keen to spend time helping out those willing to learn. So if you fetch from the Management console > Server activity log I can give you an indication.
    Also it is important that for diagnosis the server activity log level is set to verbose mode Management console> Settings > Advanced > Verbose logging. And restart all services.
  5. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Hi Mark,
    The server activity log from the console only contains a few minutes of detail though - and these investigations are always done after the fact ;-). Would there not be a complete logfile in the file system somewhere? If I knew which one to send, I'd do so. (I do have verbose logging on, btw).
    The snip I previously sent was from one of the logfiles in the file system - it was the only file that I could find the outside callers digits within.
    Thanks - Les.
  6. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Probably the best thing to do is generate support info and sift trough the files there, you will find quite a few to go on. phonesystem.log is where I normally begin to identify problems from, depending on the situation, it is the day version of the server activity log.
    What exactly are you trying to achieve I understood you wanted to understand the logic of the log with the call flow. Or have I managed to go off the beaten track?
  7. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    I am trying to give the end customer a detailed explanation of what his customer did when he called in. So yes, trying to understand call logic for that particular call.
    I'll generate support and see what I can provide.
    Thanks - Les.
  8. mfm
    mfm Active Member
    Mar 4, 2010
    641
    No problem, have a look, paste it and ill clarify it for you.
