Read-only field status ignored
Discussion in '3CX Phone System - General' started by Sopock, Dec 4, 2016.
  1. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Hi!
    It seems that any read only field from (existing) template can be edited when adding new trunk.
    I also wonder how to set custom field value in template?
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Still not resolved in beta. This may cause increased number of support queries when user could change value which is not supposed to be changed?:confused:
