Reading dmp file?
Discussion in 'Windows' started by myname24, Jun 1, 2015.
  1. myname24
    Jun 1, 2015
    A user's 3CX softphone keeps crashing while she's on a call. I have quite a few dmp files but they're in binary. What can I use to look at them and try to determine why it keeps crashing? 10 other users in the office have no issues. They're all running the same version and applications on their computers.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Which version of 3CXPhone are you running ? Is it provisionned using a welcome email ?
    Is the machine fully up-to-date on windows updates ? .NET ?
    If any antivirus/antimalware/http proxy/VPN on the machine please review http://www.3cx.com/blog/docs/3cxphone-presence-self-help/
