In order to generate a random file name, you need to use a C# expression. For example:1. Generate a random file name.
Regarding the second question, you don't have this information before you transfer the call. Your CFD app is processing the call before sending it to the agent, so you can't know this. If you need this information, you will need to check the CDRs, but not from a CFD app. Please note that CFD apps are only executed when they receive an inbound call.2. write to the file the extension number that received the call in the queue?
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
