Real-time call audio output
Discussion in '3CX Phone System - General' started by tcu, Dec 8, 2015.
  1. tcu
    tcu
    Dec 8, 2015
    I am researching PBX solutions for a simulation center. This would just be internal calling... no trunk lines. However, we need one specific feature. We need to be able to output the audio from calls to a mixer for recording by an external device. Possible?
    11,113
    329
    Someone else may have another answer, but I would say that unless you had some NSA type monitoring equipment, you would only be able to do at at the set (where the call was answered) itself.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Version 12.5 had line in feature. A feature that was deprecated because it depends on named pipes and not compliant for cloud systems..
    But since this is a simulation center, I guess it is ok..
