Reason: Q.850;cause=127;text="interworking unspecified"
Hans Kuhl
I get the following error on one specific number:
22.09.2017 12:03:40 - Leg L:9084.6[Line:10000>>040xxxxxxx] is terminated: Cause: 488 Not Acceptable Here/INVITE from 213.148.xxx.xxx:5060
22.09.2017 12:03:40 - L:9084.6[Line:10000>>040xxxxxxx] got Terminated Recv 488/INVITE from 213.148.xxx.xxx:5060 tid=d3e0650b89a5b242 Call-ID=IrNdf_sEep0Xm--puWsG2g..: SIP/2.0 488 Not Acceptable Here Via: SIP/2.0/UDP 192.xxx.xxx.xxx:5060;received=185.xxx.xxx.xxx;branch=z9hG4bK-524287-1---d3e0650b89a5b242;rport=5060 To: "040xxxxxx"<sip:[email protected]:5060>;tag=SDgqpe499-rol8hm7o From: "Hans Kuhl"<sip:[email protected]:5060>;tag=267afd0a Call-ID: IrNdf_sEep0Xm--puWsG2g.. CSeq: 2 INVITE Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR" Reason: Q.850;cause=127;text="interworking unspecified" Content-Length: 0
22.09.2017 12:03:40 - Terminated from "040xxxxxx"<sip:[email protected]:5060>;tag=SDgqpe499-rol8hm7o to "Hans Kuhl"<sip:[email protected]:5060>;tag=267afd0a; reason: Error
Hello @Hans Kuhl
Please do make sure, that you are using the latest supported firmware(you can find all the supported firmware here), that you have configured port forwarding correctly and that you have disabled SIP ALG.
Thank you, i'll be waiting for your feedback
Thanks for reply, but where can I format all outgoing numbers to this "<sip:+49..." format ?
PS: obviously most of outbound calls, about 99% do work!.....
could you determine where the 040XXX number originated from?
An extension?
Incoming from another trunk forward to external?
from an extension, we use phone model "Yealink T21P E2" with latest firmware
other destinations in this city work, the called number is reachable by mobile phone.
Log after adding outbound rule to format number:
26.09.2017 09:19:44 - Call to T:Line:10000>>+4940******@[Dev:sip:100******@sipconnect.qsc.de:5060] from L:9821.1[Extn:685] failed, cause: Cause: 488 Not Acceptable Here/INVITE from ***.***.***.***:5060
26.09.2017 09:19:44 - L:9821.2[Line:10000>>+4940******] got Failure: Failure Recv 488/INVITE from ***.***.***.***:5060 tid=1e368c5c69b2d04e Call-ID=IKQ1tww9lOBNUZMTAKE1mQ..: SIP/2.0 488 Not Acceptable Here Via: SIP/2.0/UDP ***.***.***.***:5060;received=***.***.***.***;branch=z9hG4bK-524287-1---1e368c5c69b2d04e;rport=5060 To: "+49406******"<sip:+4940******@sipconnect.qsc.de:5060>;tag=SDnldu799-6oc1h76c From: "Hans Kuhl"<sip:+492173******@sipconnect.qsc.de:5060>;tag=f8fc7f35 Call-ID: IKQ1tww9lOBNUZMTAKE1mQ.. CSeq: 2 INVITE Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR" Reason: Q.850;cause=127;text="interworking unspecified" Content-Length: 0
26.09.2017 09:19:44 - [CM503003]: Call(C:9821): Call to "+4940****** <sip:+4940******sipconnect.qsc.de:5060> has failed; Cause: 488 Not Acceptable Here/INVITE from ***.***.***.***:5060
26.09.2017 09:19:44 - Session 4747478 has failed in leg L:9821.2[Line:10000>>+4940****** ; Cause: 488 Not Acceptable Here/INVITE from ***.***.***.***:5060
26.09.2017 09:19:44 - Failure from "+4940******"<sip:+4940******@sipconnect.qsc.de:5060>;tag=SDnldu799-6oc1h76c to "Hans Kuhl"<sip:+492173******@sipconnect.qsc.de:5060>;tag=f8fc7f35
26.09.2017 09:19:44 - [CM503025]: Call(C:9821): Calling T:Line:10000>>+4940******@[Dev:sip:100******@sipconnect.qsc.de:5060] for L:9821.1[Extn:685]
26.09.2017 09:19:44 - Route to L:9821.2[Line:10000>>+4940******] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=34b2e452639f0461 Call-ID=IKQ1tww9lOBNUZMTAKE1mQ..: INVITE sip:+4940******@sipconnect.qsc.de:5060 SIP/2.0 Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---34b2e452639f0461;rport Max-Forwards: 70 Contact: <sip:100******@***.***.***.***:5060> To: "+4940******"<sip:+4940******@sipconnect.qsc.de:5060> From: "Hans Kuhl"<sip:+492173******@sipconnect.qsc.de:5060>;tag=f8fc7f35 Call-ID: IKQ1tww9lOBNUZMTAKE1mQ.. CSeq: 1 INVITE Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE Content-Type: application/sdp Supported: replaces, timer P-Asserted-Identity: <sip:+492173******@sipconnect.qsc.de:5060> Content-Length: 673
it's still not working, no more ideas ?
If the issue is only with the specific number and you have tried the correct format then i would suggest the next step is to contact your provider and ask them why the calls to this specific number are rejected. If the not acceptable here message originates from their IP then they should be able to provide some insight as to what the issue is
Reactions: John Ranger
Get 3CX - Absolutely Free!
3CX
