Rebound behavior bug?
Discussion in '3CX Phone System - General' started by matictec, Jul 15, 2010.
  1. matictec
    matictec New Member
    Mar 31, 2008
    188
    In V8 rebound behave as follow:
    Call on my phone > no answer > pbx make call to my mobile phone
    Caller hear: try to locate ...
    In V9 rebound behave as follow:
    Caller hear: please pronaunce your name then press # > after this have been done >try to locate ...
    is this correct? could this be happened because of the upgrade from V8 to V9?
  2. carolinainnovative
    May 4, 2009
    369
    5
    In v8, it was a blind forward.
    V9 introduced rebound which adds the extra functionality. If you don't like it, uncheck "rebound" in your forward rules. It will return to the old functionality of blind forwarding.
  3. matictec
    matictec New Member
    Mar 31, 2008
    188
    because of my moderate english perhaps my problem is not clearly enough. Please excuse me.
    Another try:
    With V8 and rebound the caller here directly the prompt "try to locate...". no action is needed by the caller.
    With V9 the caller here first the prompt "please pronounce your name and then press #". the caller has to pronounce his name and has to press # to here the next prompt like in V8 "try to locate...". The first prompt is unnecessary and is confusing.
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I dont think the prompt is unnecessary, I wouldnt have it any other way personally.
    The problem with the current system is that there is a 20 second delay if no button is pressed. This should either wait for no sound or only be 5-10 second long
  5. carolinainnovative
    May 4, 2009
    369
    5
    To borrow a phrase from microsoft - "its not a bug, its a feature!" - and in this case, it truly is a feature. It allows you to pre-screen your calls. If you don't like it, you can always turn off rebound. your calls will still forward to your cell, they just won't be pulled back to your corporate extension if you don't answer your cell.
  6. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Yes we are planning to switch off call screening and make it optional. So there will be the old v8 behavior and optional screening. Will be an option in the global settings.
