Rebound on V9
Discussion in '3CX Phone System - General' started by pjr, Dec 3, 2010.
  1. pjr
    pjr New Member
    Oct 5, 2009
    154
    We have just setup our first v9 server and are testing the rebound feature.
    I have it setup as follows
    Internal extension 5002 setup to forward unanswered calls after 2 seconds to an external mobile number.
    Ext 5002 also has call screening enabled.
    If I call the internal extension of 5002 or it's DDI, It rings briefly before I get asked to record my name and press any key, I then get told the PBX is trying to locate 5002 - as I would expect.
    The mobile that's configured to receive the forwarded calls from 5002 rings but the message from the PBX is just the callers phone number ID, and not the name greeting that was recorded?
    How do we get this feature working?
    Also, if the user 5002 has a personal identification message recorded does the the voice prompt the caller hears, change from saying, please wait whilst we try to locate "5002", to play the users personal identification message instead?
    Paul
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Hi, Please update your system prompts and try again.
    If problem persists - restart your web server and try again.
    Thanks and Regards
  3. pjr
    pjr New Member
    Oct 5, 2009
    154
    System prompts were out of date - now updated.
    Entire server restarted and the issue remains.
    Paul
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Delete then that Prompt - and download it again.
    Restart Web server there is no need to restart all machine.
    If problem persist contact me mb@3cx.com
  5. pjr
    pjr New Member
    Oct 5, 2009
    154
    Which prompt do i need to delete and where would I find it?
    Paul
  6. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Hi, are you using the Standard English prompt?
    Go to IVR/Prompts/Sets/ResponseOrdering.vxml
    It should be like this -
    <?xml version="1.0" encoding="utf-8"?>
    <IVROrderSet culture="jp">
    <response name="QUEINTRO" order="YOUR_AT_POSITION+$Num$+QUEUE_TOBE_CONNECTED" />
    <response name="VMDATETIME" order="TIME_IS+$Date$+EMPTY+$Time$" />
    <response name="VMCALLER" order="MSG_FROM+$PhoneNum$" />
    <response name="VMMSGDEL" order="$Num$+$Messages$+DELETED" />
    <response name="VMRECINTRO" order="RECYA+$Prompt$+THENPRESPND+BEEP" />
    <response name="EXTNUMBER" order="PLSENTER+EXTNUM" />
    <response name="ENTERPIN" order="PLSENTER+PIN+THENPRESPND" />
    <response name="ENTERNEWPIN" order="PLSENTER+NEW_PIN_CODE+THENPRESPND" />
    <response name="YOURNEWPIN" order="YOUR+NEW_PIN_CODE+IS+$PIN$" />
    <response name="PINCONFIRM" order="TO_SAVE+CONFIRM" />
    <response name="MENUENTRY" order="PRESSSTAR_TOPLAY+PRESSNINE_FOROPTIONS+TOEXIT_PRESSPOUND" />
    <response name="DIALOUT" order="PLSENTER+NUMBER_ENT+THENPRESPND" />
    <response name="NEWSELFID" order="TORECNEW+MSG_SELFID+MSGREC_MNU2" />
    <response name="NEWGREETING" order="TORECNEW+MSG_GRT+MSGREC_MNU" />
    <response name="ENTERUSERNAME" order="PLSENTER+USER_NAME" />
    <response name="BOOMGREET" order="PLSWAITLOCATE+$PhoneNum$" />
    <response name="BOOMACCEPTGREET"
    order="UHVCALL+$VMAILAUDIO$+$PhoneNum$+EMPTY+PRESS1TOTAKECALL+EMPTY+PRESSSENDTOVMAIL" />
    <response name="BOOMNOTLOCATED" order="USERUNAVAIL+REDIRVMAIL" />
    <response name="PROFSTATUSOPT" order="STATUS_MENU" />
    </IVROrderSet>
  7. nb
    nb Support Team
    Jun 7, 2007
    2,117
    146
    HI We made some changes to the prompts.
    Download the system prompt you are using one final time and try this again - we found an issue in other languages.
    Can you let us know which system voice prompt language you are using?
    If a fresh download does not fix the problem, restart the webserver or restart the machine quickly and your problem should be resolved + the call screening prompt will be played.
  8. brianlgrimm
    Dec 17, 2010
    19
    I would like this as well.
    In looking at ResponseOrdering.vxml, it appears that this line controls this:
    What variable can I replace $PhoneNum$ with that would play the recorded self identification message instead?
