Rec function disable on softphones(globally)
Discussion in 'Ideas' started by naveensenapathy, Nov 10, 2017.
Rec function disable on softphones(globally) 5 5 4votes
5/5, 4 votes
  1. naveensenapathy
    Apr 24, 2013
    10
    5
    Few customers asking do disable "Rec" option for softphones(after answer the call) from 3CX console globally for all softphones. Because agents should not disable the call recording function from 3Cx softphons. In future if you add this function it would be helpful for call centers.
  2. Silly English Kniggit
    Sep 13, 2017
    220
    85
