Reccomend me a UK based SIP trunk provider please
Discussion in '3CX Phone System - General' started by Fatboy40, Aug 2, 2010.
  1. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    As part of an office move the business I work for has decided to try and go with a 3CX system (so probably v 9) rather than re-locate our old PBX. This is something we'll be thinking about setting up within the next four to six weeks.
    Now I have the task of finding a good SIP trunk provider in the UK. A couple of things are that we need to be able to port around 45 numbers/DDI's over from British Telecom, and that we do not wish to use a SIP trunk providers own Internet connectivity as we have a 4Mb syncronous product from Easynet (EtherStream).
    So, could someone please reccomend a SIP trunk provider in the UK that meets the above, is compatible with 3CX, and will have low international call charges comparable with those available using traditional CPS on an ISDN30 ?.
    Thanks.
  2. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    So far I've spoken to 'VoIP Unlimited' (http://www.voip-unlimited.net), who on the phone at least seem to be what we need and being a 3CX reccomended SIP trunk provider tick the box...
  3. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    As I have said in another post, we use Voip Unlimited. Their support is good and the company is very responsive.
    Richard Crabb
    http://www.dorsetphonesystems.com
  4. sipero123
    Nov 24, 2008
    94
    I suppose it also depends whether you just want a SIP Trunk provider or whether you need an end to end solution less the internet connectivity.
    We do use Voip Unlimited and a few other 3CX recommended Trunk providers. We can however also install and fully support your 3CX as well and have our own VOIP server in the BlueSquare Datacentre to which we can connect either your individual extensions or your 3CX PBX.
    Please feel free to get in touch if you would like to discuss this further. We are able to offer extremely competative rates and a personal service.
    Jonathan Hamon
    john@sipero.com
    http://www.sipero.com
