Reccomendations Please
Discussion in '3CX Phone System - General' started by woodduck, Jul 25, 2007.
  1. woodduck
    Jun 15, 2007
    6
    I need reccomendations for a VOIP Gateway. I would like one with 2 FXO ports. I want to build a demo machine with 2 line capabilities using PSTN lines. I could get by with only 1 FXO port, because right now finances is the important point.
    I would like to get one under $50.00 if possible, either new or via E-bay is ok.
    Thanks in advance.
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    If you search here you will find lots of info, but recommensations are:
    Linksys PAP2, SPA3000 series, GrandStream Handytone 488.
    Those seem to be the most popular but if you check:
    https://www.3cx.com/support/voip-gateways/
    you can see the list of ones that 3CX supports and doc to configure them.
    #2 RobLloyd, Jul 25, 2007
  3. woodduck
    Jun 15, 2007
    6
    The PAP2 appears to have only FXS Ports. I want to connect to PSTN existing lines, not to a VOIP provider.
    Also is the a inexpensive Gateway that does not include a router? I have an existing setup and just want to add to it.
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Grandstream HT488 - 1 x FXO and 1 x FXS.
    Device Mode: NAT Router or Bridge
