receive and send faxes
Discussion in '3CX Phone System - General' started by Anonymous, Sep 21, 2006.
  1. Anonymous
    Anonymous Guest
    I'd like to ask it's possible to send and receive faxes in the future?
    Greetings,
    Mathias
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,992
    308
    Faxes
    Yes, this is something we are working on in the future. It would require a gateway though that is T38 capable (most are) and then some form of fax server.
    In the meantime i suggest its easier to connect the line directly to the fax machine...
  3. Anonymous
    Anonymous Guest
    Windows XP has fax send and receive capabilities. I've only played with it but it sure would be nice if it were combined with Ghostscript (a la PDFCreator) with a smattering of automation! :lol:
    http://www.microsoft.com/windowsxp/using/setup/learnmore/crawford_02october21.mspx
    http://support.microsoft.com/kb/306550/
    http://www.cs.wisc.edu/~ghost/
    http://www.pdfforge.org/products/pdfcreator
