Solved Receive inbound Faxes at FAX Machine via ATA
Discussion in '3CX Phone System - General' started by mobilowa, Sep 23, 2017.
  1. mobilowa
    Feb 5, 2015
    41
    I have SIP trunk which supports T.38 with 10 DIDs block
    I use 1 DID for FAX out of the block
    I connect FAX Machine to 3CX via ATA Cisco SPA112
    I configured a FAX extension with default caller ID (this is same FAX DID), but here I can not link a DID to receive incoming faxes. there is no options available
    I can link DIDs under FAX server, but FAX server is used to automatically convert incoming Faxes to PDF and forwarded to the email specified
    Not to send incoming Faxes to Analog Fax Machines connected via ATA
    So How can I configure 3CX to receive faxes on specific DID and deliver it to Fax machines via ATA. instead of sending to email
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    692
    216
    Rather trivial -- into inbound rules select send fax to fax device ??? -- the number of your fax extension ata
  3. mobilowa
    Feb 5, 2015
    41
    Thx you !
