Receiving fax with Windows Server 2003 Fax Services
Discussion in '3CX Phone System - General' started by kleon, May 11, 2010.
  1. kleon
    Apr 8, 2010
    9
    I setup my 3cx with Linksys 3102 as the tutorial .
    Made a extension (118 as the tutorial) ive managed successfully to receive fax on an external fax machine , but when i connect the ata port to a modem attached to my windows server 2003 , the extension forwards the fax call to server , the call was answered but after 2-3 seconds , the call is terminated.
    Please advice ,
    thank you!
    Here is the log:
    15:24:17.531 [CM503008]: Call(5): Call is terminated
    15:24:08.578 Active calls counted toward license limit: [5]
    15:24:06.281 [CM503007]: Call(5): Device joined: sip:118@192.168.1.120:5060
    15:24:02.359 [CM505001]: Ext.118: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:118@192.168.1.100:5060]
    15:24:02.359 [CM503002]: Call(5): Alerting sip:118@192.168.1.120:5060
    15:24:02.328 [CM503025]: Call(5): Calling Ext:Ext.118@[Dev:sip:118@192.168.1.120:5060]
    15:24:02.234 [CM503004]: Call(5): Route 1: Ext:Ext.118@[Dev:sip:118@192.168.1.120:5060]
    15:24:02.234 [CM503010]: Making route(s) to <sip:118@127.0.0.1:5060>
    15:24:02.234 [CM505002]: Gateway:[SPA-3102] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:10002@192.168.1.100:5060]
  2. kleon
    Apr 8, 2010
    9
    Anybody Please??
