Receiving faxes using faxback
Discussion in '3CX Phone System - General' started by fychan, Jul 3, 2010.
  1. fychan
    Sep 4, 2009
    9
    Hi .....
    Anyone can advice if FaxBack (VoIP Plugin) works for receiving fax?
    I do see a thread saying there are issues with Sending fax....
    Does it only support 32-Bit OSes?
    regards
    Fei Yu
  2. dab
    dab
    Nov 1, 2009
    67
    What's the goal of using faxpack instead of the 3CX builtin faxserver?
  3. carolinainnovative
    May 4, 2009
    369
    6
    Faxback provides a host of features that the 3cx fax device just doesn't provide including some advanced routing, fax archiving, etc.
