Receiving large faxes fails
Discussion in '3CX Phone System - General' started by jobe, Nov 3, 2010.
  1. jobe
    Sep 30, 2010
    6
    I'm having a problem receiving large faxes. I can receive a 1-4 page fax, but anything larger seems to get cut off after the 5th page.
    I'm using a voip provider - CallCentric.
    Using CallCentric's own fax reception feature, I can receive a 9 page fax no problem.
    Any thoughts?
