Receiving Multiple Concurrent Inbound Faxes
Discussion in '3CX Phone System - General' started by Jes.amos, Nov 1, 2017.
Tags:
  1. Jes.amos
    Nov 1, 2017
    22
    Does anyone know how many concurrent faxes the system can handle or if it can handle concurrent faxes?
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    The 3CX license should be the limit. I haven't experienced problems with several simultaneous fax calls (both ATA and fax-to-mail).
    Jes.amos likes this.
