recept ext showing busy at 1 call
Discussion in '3CX Phone System - General' started by tqhx, May 16, 2010.
  1. tqhx
    Apr 3, 2010
    28
    [CM503020]: Normal call termination. Reason: Busy
    09:25:24.029
    [CM503016]: Call(2299): Attempt to reach <sip:100@192.168.114.234:5060> failed. Reason: Busy
    09:25:24.029
    [CM503003]: Call(2299): Call to sip:100@192.168.114.234 has failed; Cause: 486 Busy Here; from IP:192.168.114.175:5060
    09:25:23.982
    [CM503025]: Call(2299): Calling Ext:Ext.100@[Dev:sip:100@192.168.114.175:5060]
    09:25:23.919
    [CM503004]: Call(2299): Route 1: Ext:Ext.100@[Dev:sip:100@192.168.114.175:5060]
    09:25:23.919
    [CM503010]: Making route(s) to <sip:100@192.168.114.234:5060>
    This just started happening. Prior to this the phone was accepting multiple calls. Any ideas?
    GS GXW4108 is my gateway and the phone is a SPA525G. The phone has all 6 lines set to enabled as ext1. I tried setting the rules to basic, and having i want to be able to accept more than 1 call at a time checked off.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    IP:192.168.114.175:5060 is busy.
    Who is it? ("GS GXW4108 is my gateway and the phone is a SPA525G")
  3. tqhx
    Apr 3, 2010
    28
    Its the receptionist phone. All incoming lines from the pstn are directed to it (ext 100 which is a cisco 525g)
  4. tqhx
    Apr 3, 2010
    28
    Was able to get on site for a while today. Narrowed it down to being the phone itself. I reset it to factory and provisioned again and its working ok. Not really sure what happened
  5. SY
    3CX Support
    Jan 26, 2007
    1,825
    Excuse me for late response.
    In log you provided the phone answers busy.
    PBX cannot stop the phone to do it :(
