Receptionist ability to send call directly to vmail
Discussion in '3CX Phone System - General' started by sunstate, Mar 24, 2011.
  1. sunstate
    sunstate Member
    Dec 16, 2009
    257
    I have a client that wants the receptionist to be able to send calls directly to people's voicemail. I see the *4ext dialcode, but that seems to be for picking up the handset and dialing straight to someone's vmail, not send an active call to someone else's vmail. Is there any way to do this? I have seen the feature request for a transfer to vmail button (http://3cx.ideascale.com/a/dtd/Transfer-to-voicemail-button/87827-9854) and voted for it, but hopefully there is some way to accomplish this now.
  2. komputer
    Aug 3, 2009
    5
    It can be done very easily
    1. Call comes in receptionist answers then TRNF(XFER) *4ext TRNF(XFER)
    2. Use the 3CX Assistant and right click on call and transfer *4ext
    Note: TRNF(XFER) is denoted as the TRANSFER button on your phone depending on model, some phones it's XFER and some TRANSFER.
  3. willow
    willow Member
    Mar 1, 2011
    471
    agree
  4. beaterku
    Dec 16, 2010
    42
    I created dummy extensions that are not registered that have forwarding rules to voicemail.
    Ex: I have 4 extensions:
    101
    102
    103
    104
    I created 4 dummy extensions:
    201 - forwards to 101 vmail
    202 - forwards to 102 vmail
    203 - forwards to 103 vmail
    204 - forwards to 104 vmail
    201-204 appear in the 3cx assistant and I can just drag and drop straight to vmail.
  5. sunstate
    sunstate Member
    Dec 16, 2009
    257
    I swear I tried that before I posted and it didn't work. But I just tried now and it worked fine. I am doing it on an Aastra right now, before when I was trying it was on a Yealink. I'll give the Yealink a shot tomorrow again.
    This is actually what I was going to do if I couldn't get the *4ext to work.
