Receptionist can not transfer to the ext.of unregistered ??
Discussion in '3CX Phone System - General' started by kate, Jan 14, 2008.
  1. kate
    Jan 14, 2008
    18
    Extension 103 setting:If the ext103 is unregeistered that will forward to the extension 104.
    The problem is When a caller calls into the system the digital receptionist answers the call and plays a welcome message.
    The caller then dials Ext. 103 and is transferred to the extension.
    But receptionsit said "call transfer failed" . why ??
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    just to have you understand
    incomming call to DR
    DR play message
    if caller dial 103 while messages is played
    and 103 is unregistered and it is configured to forward to 104 if unregistered
    1. Is 104 registered?
    2. did the mediaserver recogniced the DTMF Tone? what does the log say?
    3. try to config to the DR to forward to 103 if 1 is pressed and 104 if 2 is pressed. then try calling and press 1 instead of 103. and if failed press 2 to veryfy he send the call to 104.
    Andy
  3. kate
    Jan 14, 2008
    18
    17:51:08.328 Call::RouteFailed :[CM503014]: Call(49): Attempt to reach [sip:103@127.0.0.1] failed. Reason: Not Registered
    17:51:08.328 CallCtrl::eek:nSelectRouteReq :[CM503015]: Call(49): Target is not registered: Ext:Ext.103
    17:50:58.421 Call::RouteFailed :[CM503014]: Call(49): Attempt to reach [sip:103@127.0.0.1] failed. Reason: Not Registered
    17:50:58.421 CallCtrl::eek:nSelectRouteReq :[CM503015]: Call(49): Target is not registered: Ext:Ext.103
    1. Ext 104 is registered.
    2. 103 is unregistered and it is configured to forward to 104 . If caller dial 103 while messages is played "call transfer failed"
    3.I pressed 1 (forward to 103) ==>I got "call transfer failed"
    I pressed 2 (forward to 104) ==>It's no problem with the call
    If I call the ext 103 form ext 102, It can be work well, the phone call will forwad to the ext 104 .
  4. Ricambi America
    Nov 10, 2007
    61
    I am experiencing the same problem on 5.0.3790.0.
  5. silentfun
    silentfun Member
    Dec 11, 2006
    364
    Re:
    17:50:58.421 Call::RouteFailed :[CM503014]: Call(49): Attempt to reach [sip:106@127.0.0.1] failed. Reason: Not Registered
    why is ext 106 also involved?
  6. Ricambi America
    Nov 10, 2007
    61
    In my case, the logs show:
    15:52:07.656 Call::RouteFailed [CM503014]: Call(112): Attempt to reach [sip:201@127.0.0.1] failed. Reason: Not Found
    15:52:07.656 CallCtrl::eek:nSelectRouteReq [CM503013]: Call(112): No known route to target: [sip:201@127.0.0.1]
    The phone is configured extremely simple:
    Extension 201
    Forward All Calls (regardless of registration) to x-xxx-xxx-xxxx (my external number)
    I have also added extension 201 into a known working "outbound rule"
    Any ideas?
  7. silentfun
    silentfun Member
    Dec 11, 2006
    364
    this indicates the outbound rule is not ok
    Andy
  8. kate
    Jan 14, 2008
    18
    Re: I tried it again, it still could not work ....
    :cry: 10:40:19.968 Call::Terminate :[CM503008]: Call(54): Call is terminated
    10:40:19.953 LineCfg::getInboundTarget :[CM503011]: Inbound office hours' rule for LN:10000 forwards to DN:800
    10:40:17.843 Call::Terminate :[CM503008]: Call(53): Call is terminated
    10:40:10.687 Call::RouteFailed :[CM503014]: Call(54): Attempt to reach [sip:100@127.0.0.1] failed. Reason: Not Registered
    10:40:10.687 CallCtrl::eek:nSelectRouteReq :[CM503015]: Call(54): Target is not registered: Ext:Ext.100
    10:39:57.750 LineCfg::getInboundTarget :[CM503011]: Inbound office hours' rule for LN:10000 forwards to DN:800
    10:39:57.734 CallCtrl::eek:nLegConnected :[CM503007]: Call(54): Device joined: sip:10000@192.168.1.4:5060
    10:39:56.906 CallCtrl::eek:nLegConnected :[CM503007]: Call(54): Device joined: sip:
    10:39:56.906 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(54): Calling: IVR:800@[Dev]
    10:39:56.890 Line::printEndpointInfo :[CM505002]: Gateway:[pstn] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [056 12-35-9983931] Transport: [sip:192.168.1.3:5060]
    10:39:56.890 LineCfg::getInboundTarget :[CM503011]: Inbound office hours' rule for LN:10000 forwards to DN:800
    10:39:56.875 CallCtrl::eek:nIncomingCall :[CM503001]: Call(54): Incoming call from 10000@(Ln.10000@pstn) to [sip:800@phonesystem.mydomain.com:5060]
    10:39:56.859 LineCfg::getInboundTarget :[CM503011]: Inbound office hours' rule for LN:10000 forwards to DN:800
    10:39:52.859 MediaServerReporting::DTMFhandler :[MS211000] C:53.2: 220.228.58.89:25764 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
    10:39:52.578 CallCtrl::eek:nLegConnected :[CM503007]: Call(53): Device joined: sip:xxxxxxxxxx@220.228.58.70:5060
    10:39:52.562 CallCtrl::eek:nLegConnected :[CM503007]: Call(53): Device joined: sip:802@125.225.139.173:15001
    10:39:52.484 Line::printEndpointInfo :[CM505003]: Provider:[voip] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.1.3:5060]
    10:39:51.781 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(53): Calling: VoIPline:10001@[Dev:sip:xxxxxxxxxx@220.228.58.70:5060]
    10:39:51.734 CallCtrl::eek:nIncomingCall :[CM503001]: Call(53): Incoming call from Ext.802 to [sip:xxxxxxxxxx@122.116.108.165]
    10:39:34.156 Call::Terminate :[CM503008]: Call(52): Call is terminated
    :cry: 10:39:29.453 CallCtrl::eek:nRerouteReq :[CM503005]: Call(52): Forwarding: Ext:103@[Dev:sip:103@122.116.108.165:5060]
    10:39:29.453 Call::RouteFailed :[CM503014]: Call(52): Attempt to reach [sip:100@122.116.108.165] failed. Reason: Not Registered
    10:39:29.453 CallCtrl::eek:nSelectRouteReq :[CM503015]: Call(52): Target is not registered: Ext:Ext.100
    10:39:29.437 CallCtrl::eek:nIncomingCall :[CM503001]: Call(52): Incoming call from Ext.802 to [sip:100@122.116.108.165]
    I tried it again ~ The called form ext 802 to ext 100, It's wroking flawlessly with internal calls. (Configure behavior if this extension is unregistered and a call is received for this ext 103)
    But when I made a incoming calls , it could not forward to the ext 103 . (If caller dial 103 while messages is played "call transfer failed")
    My version is v5. 3790 .
    Thank you ~~
  9. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i have set up this to test your needs:
    10004 Line to ext. 203
    rule for 203 on unregistered forward to 200 (and 203 is unregistered)
    then i called the phone number associated with line 10004 and look what happens and 200 was ringing.
    i have included the logfile
    Time Function Message
    06:48:16.019 Call::Terminate [CM503008]: Call(57): Call is terminated
    06:48:15.988 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10004 forwards to DN:203
    06:48:03.879 Extension::printEndpointInfo [CM505001]: Ext.200: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2020 1.1.4.17] Transport: [sip:99.88.25.24:5060]
    06:48:03.879 CallCtrl::eek:nAnsweredCall [CM503002]: Call(57): Alerting sip:200@99.230.126.104:63466;transport=udp;user=phone
    06:48:03.769 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10004 forwards to DN:203
    06:48:03.754 MediaServerReporting::SetRemoteParty [MS210002] C:57.2:Offer provided. Connection(transcoding mode): 99.88.25.24:9014(9015)
    06:48:03.488 CallCtrl::eek:nRerouteReq [CM503005]: Call(57): Forwarding: Ext:200@[Dev:sip:200@99.230.126.104:63466;transport=udp;user=phone]
    06:48:03.488 Call::RouteFailed [CM503014]: Call(57): Attempt to reach [sip:203@99.88.25.24:5060] failed. Reason: Not Registered
    06:48:03.488 CallCtrl::eek:nSelectRouteReq [CM503015]: Call(57): Target is not registered: Ext:Ext.203
    06:48:03.488 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:203@99.88.25.24:5060]
    06:48:03.488 MediaServerReporting::SetRemoteParty [MS210000] C:57.1:Offer received. RTP connection: 217.10.67.13:14606(14607)
    06:48:03.488 CallLeg::setRemoteSdp Remote SDP is set for legC:57.1
    06:48:03.488 Line::printEndpointInfo [CM505003]: Provider:[0991580098012 SIPGATEde] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:99.88.25.24:5060]
    06:48:03.488 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10004 forwards to DN:203
    06:48:03.426 CallCtrl::eek:nIncomingCall [CM503001]: Call(57): Incoming call from 09920792437@(Ln.10004@0991580098012 SIPGATEde) to [sip:203@99.88.25.24:5060]
    06:48:03.191 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10004 forwards to DN:203
    06:48:03.160 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:8009801e2@99.88.25.24:5060;rinstance=12635708152e5859 SIP/2.0
    Via: SIP/2.0/UDP 217.10.79.9:5060;branch=z9hG4bK3dd1.a6d5bb44.0
    Via: SIP/2.0/UDP 172.20.40.3;branch=z9hG4bK3dd1.a6d5bb44.0
    Via: SIP/2.0/UDP 217.10.79.9:5060;received=217.10.68.222;branch=z9hG4bK6b870284
    Via: SIP/2.0/UDP 217.10.67.13:5060;branch=z9hG4bK6b870284;rport=5060
    Max-Forwards: 67
    Record-Route: [sip:217.10.79.9;lr=on;ftag=as48ca2af7]
    Record-Route: [sip:172.20.40.3;lr=on]
    Contact: [sip:09920792437@217.10.67.13]
    To: [sip:0049991580098012@sipgate.de]
    From: "09920792437"[sip:09920792437@sipgate.de];tag=as48ca2af7
    Call-ID: 65a52b4652790f42203240fc1a906d6b@sipgate.de
    CSeq: 102 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
    Supported: replaces
    Content-Length: 0
    this log is is very diferent to yours - it seems there is something not ok
    it looks like 802 is one of your internal extensions.
    what is about 800 is this DR or CallQueu or RingGroup?
    Andy
  10. kate
    Jan 14, 2008
    18
    ext 800 is the DR ~~
    when I called the ext 100 , I got the message "call transfer failed" , and then forward to the DR(800) again. (only in the incoming call)
    I don't what's happening with my 3cx ??? shock >.<~~
  11. Ricambi America
    Nov 10, 2007
    61
    Sadly, we gave up on Version 5 and rolled back to 3 late last night, in order to have this functionality work properly. I'm sorry, but the V5 perhaps does work -- but it's either poorly documented, or an oddball configuration which kept it from working on our system.
    Now, we use V3 DR's like this:
    EXT 101, if busy go to VM
    EXT 101, if no answer or unregistered go to DR 802
    DR 802 is defined with message "Press 1 for xfer to external extension (201)", or stay on the line for VM
    1-> Xfer to extension 201
    no response, wait 2 second then -> Send to VM for 101
    Seems like there are plenty of nice new features that I'm happy to pay for with V5 -- but not at the expense of crippling the business while we work through the oddities. :(
  12. kate
    Jan 14, 2008
    18
    By the way, If my configuration is that if ext101 is unregistered forward to VM , but I got a message "call tranfer failed " only, and then the call transfer to the DR(800) again .
    Should I roll back to the v3 !!! :cry:
  13. Ricambi America
    Nov 10, 2007
    61
    That's very similar to the problem we had. We're back on V3 now, and life has returned to normal.
  14. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Thanks a lot for information.
    Could you please specify, which of VoIP providers cannot handle such scenarios(transfer from the DR)?
  15. kate
    Jan 14, 2008
    18
    I used the line of PSTN.....
  16. camdeal
    Aug 13, 2007
    I have the same problem after upgrading from the latest v3.1 to latest v5.
    DR will not transfer calls to extensions (registered or not). Deliver a "transfer failed" message with same logs as above.
    Call from one ext to another (registered or not) displays a "no known route to target"
    Called from 2145551212 in to POTS line on POTS Gateway
    DR picks up and plays message and then I press 289 (to call Ext 289 which is registered and can dial out fine)
    Here is the non-verbose logs...
    15:33:30.306 Call::Terminate :[CM503008]: Call(4): Call is terminated
    15:33:30.276 Call::Terminate :[CM503008]: Call(4): Call is terminated
    15:33:30.226 LineCfg::getInboundTarget :[CM503011]: Inbound out-of-office hours' rule for LN:10011 forwards to DN:405
    15:33:23.266 Call::RouteFailed :[CM503014]: Call(4): Attempt to reach [sip:289@127.0.0.1] failed. Reason: Busy
    15:33:23.266 CallCtrl::eek:nSelectRouteReq :[CM503013]: Call(4): No known route to target: [sip:289@127.0.0.1]
    15:33:19.690 MediaServerReporting::DTMFhandler :[MS211000] C:4.1: 172.31.255.85:6000 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
    15:33:12.941 LineCfg::getInboundTarget :[CM503011]: Inbound out-of-office hours' rule for LN:10011 forwards to DN:405
    15:33:12.901 CallCtrl::eek:nLegConnected :[CM503007]: Call(4): Device joined: sip:10011@172.31.255.85:5060
    15:33:12.260 CallCtrl::eek:nLegConnected :[CM503007]: Call(4): Device joined: sip:
    15:33:12.230 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(4): Calling: IVR:405@[Dev]
    15:33:12.200 Line::printEndpointInfo :[CM505002]: Gateway:[WF POTS BANK B] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Audiocodes-Sip-Gateway-MP-118 FXO/v.5.00A.035.003] Transport: [sip:172.31.255.81:5060]
    15:33:12.200 LineCfg::getInboundTarget :[CM503011]: Inbound out-of-office hours' rule for LN:10011 forwards to DN:405
    15:33:12.150 CallCtrl::eek:nIncomingCall :[CM503001]: Call(4): Incoming call from 2145551212@(Ln.10011@WF POTS BANK B) to [sip:405@sip.netessinc.local:5060]
    15:33:12.130 LineCfg::getInboundTarget :[CM503011]: Inbound out-of-office hours' rule for LN:10011 forwards to DN:405
    In addition, DIDs and incoming calls on Nexvortex work on the first call, then subsequent calls don't come through. Have to "reregister" the line.
    After working all weekend on this, I also gave up and reverted back to v3.1 install so we can work properly Monday morning.
  17. blabla
    Jan 20, 2008
    32
    Any information when this bug was or will be fixed ?
  18. wtl
    wtl
    Aug 24, 2007
    15
    Same problem here - digital receptionist will not transfer a call to voicemail when the extension is unregistered (5.0.3790).
    I do note that if you configure "Forward all calls" for the extension to forward to voicemail, that works fine. This suggests to me that it's a bug, and not a misconfiguration.
  19. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    This bug is already found and exterminated. Update will be available quite soon (we're in test phase now)
  20. Ricambi America
    Nov 10, 2007
    61
    Bug? That's for dang sure. Here's the fix:
    Add the extension of the Digital Receptionist (in my case '800') into one of the outbound rules. Bingo, it works.
    Now, if DR gets a call, it tries to ring 101, 102, 103, etc. If no answer, it forwards to ext 500 -- which is our always 'unregistered' general mailbox. The outbound rule was needed for DR to get the call into 500. We struggled for a long time on this one, but seems to work now just perfectly.
