Receptionist transfers call and extention doesn't stop ringi
Discussion in '3CX Phone System - General' started by jasit, Jun 17, 2014.
  1. jasit
    jasit New Member
    Feb 12, 2013
    171
    We have been having the issue lately where the receptionist will transfer the call to a extention and the extention will ring without ever going to voicemail. The extentions are set to goto voice mail after 15 seconds.
    We are using version ll.4a with yealink 32g phones. The receptionist can pick up the call again so it's not a dead call per say. The phone had rang for over two minutes. Any ideas would be greate.
    jasit
    17-Jun-2014 14:59:57.659 Leg L:348.4[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.5.134:5062
    17-Jun-2014 14:59:57.658 [CM503003]: Call(C:348): Call to <sip:333@192.168.5.3:5060> has failed; Cause: 487 Request Terminated/INVITE from 192.168.5.134:5062
    17-Jun-2014 14:59:57.546 [CM503008]: Call(C:350): Call is terminated
    17-Jun-2014 14:59:57.427 [CM503007]: Call(C:350): Extn:330 has joined, contact <sip:330@192.168.5.124:5062>
    17-Jun-2014 14:59:57.376 [CM503007]: Call(C:350): Extn:330 has joined, contact <sip:xxxxxxxxx@xxxxx.net:5060>
    17-Jun-2014 14:59:57.376 [CM503025]: Call(C:350): Calling T:Extn:330@[Dev] for L:350.1[Extn]
    17-Jun-2014 14:59:57.330 [CM503027]: Call(C:350): From: Extn:330 ("Jeanette Sterne" <sip:330@192.168.5.3:5060>) to T:Extn:330@[Dev]
    17-Jun-2014 14:59:57.330 [CM503004]: Call(C:350): Route 1: from L:350.1[Extn] to T:Extn:330@[Dev]
    17-Jun-2014 14:59:57.329 [CM503001]: Call(C:350): Incoming call from Extn:330 to <sip:*20*333@192.168.5.3:5060>
    17-Jun-2014 14:59:27.903 Currently active calls - 1: [348]
    17-Jun-2014 14:58:57.899 Currently active calls - 1: [348]
    17-Jun-2014 14:58:25.896 Currently active calls - 1: [348]
    17-Jun-2014 14:58:11.030 Leg L:348.3[Extn] is terminated: Cause: BYE from 192.168.5.124:5062
    17-Jun-2014 14:57:53.893 Currently active calls - 1: [348]
    17-Jun-2014 14:57:23.890 Currently active calls - 1: [348]
    17-Jun-2014 14:57:10.865 Leg L:349.1[Extn] is terminated: Cause: BYE from PBX
    17-Jun-2014 14:57:10.861 [CM503020]: Call(C:349): Normal call termination. Call originator: Extn:330. Reason: Terminated
    17-Jun-2014 14:57:10.861 L:349.1[Extn] failed to reach Extn:333, reason User Requested
    17-Jun-2014 14:57:10.861 Call to T:Extn:333@[Dev:sip:333@192.168.5.134:5062] from L:349.1[Extn] failed, cause: Cause: BYE from 192.168.5.134:5062
    17-Jun-2014 14:57:10.861 Leg L:349.2[Extn] is terminated: Cause: BYE from 192.168.5.134:5062
    17-Jun-2014 14:57:10.779 [CM503025]: Call(C:348): Calling T:Extn:333@[Dev:sip:333@192.168.5.134:5062] for L:348.1[Line:10000<<4164274460]
    17-Jun-2014 14:57:09.672 [CM503025]: Call(C:349): Calling T:Extn:333@[Dev:sip:333@192.168.5.134:5062] for L:349.1[Extn]
    17-Jun-2014 14:57:09.623 [CM503027]: Call(C:349): From: Extn:330 ("Jeanette Sterne" <sip:330@192.168.5.3:5060>) to T:Extn:333@[Dev:sip:333@192.168.5.134:5062]
    17-Jun-2014 14:57:09.623 [CM503004]: Call(C:349): Route 1: from L:349.1[Extn] to T:Extn:333@[Dev:sip:333@192.168.5.134:5062]
    17-Jun-2014 14:57:09.622 [CM503001]: Call(C:349): Incoming call from Extn:330 to <sip:333@192.168.5.3:5060>
    10,758
    286
    Re: Receptionist transfers call and extention doesn't stop r
    Was this a blind, or attended transfer?
  3. jasit
    jasit New Member
    Feb 12, 2013
    171
    based on the phone settings transfer mode via dss key is set to blind transfer, should it be attended and what does that actually mean?
  4. leejor
    10,758
    286
    If all other options for the extension are correct, it should not make a difference.
    Who has this IP? Is this happening with any other extensions?
  5. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    BYE is coming from extension 333..... I would first go to extensions status node--->voicemail and assure voice mail is enabled in that extension. I'd then check forwarding rules for that extension according to your rules it should say "if the call is not answered within 15" send to my voicemail.
