Recomended Softphone
Discussion in '3CX Phone System - General' started by zakfleming, Aug 17, 2007.
  1. zakfleming
    Aug 17, 2007
    48
    what soft phone software do you recommend and why?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    I would recommend trying out X-Lite.
    The free version is available here:
    http://www.counterpath.com/index.php?menu=Products&smenu=xlite
  3. zakfleming
    Aug 17, 2007
    48
    why do you recomend it please?
  4. onekit
    Aug 3, 2007
    27
    Because it's free and comfortable. Not too large (take 5-7mb space in memory). Easy to access it from systray and so on.
  5. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I have tried several offerings and completely agree that X-Lite is a very good product. I even went with the full version for myself.
  6. zakfleming
    Aug 17, 2007
    48
    what extras does the full version have please?
  7. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    My eyebeam has 6 lines instead of 2. Its the same look but some extra features comparing to the eyebeam.
    Another thing I noticed is that with xlite I am allowed to have 1 account, but with eyebeam (paid version of xlite) I have up to 10 accounts so I can register to a voip provider directly, and to the pbx and to another pbx at the same time if I want to.
    Also If I am not mistaken transfers don't work on my free edition but on the paid they do.
    I am sure there must be some comparison chart on their website.
    Hope this helps.
    Regards
  8. VictorN
    Jun 20, 2007
    30
    I would recomend the Express Talk:
    http://www.nch.com.au/talk/index.html
    Victor
  9. onekit
    Aug 3, 2007
    27
    I want to say that you recommend Windows version of Express Talk. Isn't it?
    If you'll try to install this Express Talk (PDA version) on Pocket PC you'll don't recommend it ;). Try to see how it seems on Eten X500 Plus (640x480 screen resolution). It's terrible.
  10. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Yes. Windows version of Express Talk should be acceptable. But PDA version very bad. Too many feed back and almost no echo cancellation ....... :(
  11. VictorN
    Jun 20, 2007
    30
    I was referring only to the Windows version. I did not try the PDA edition.
    Regards
    Victor
  12. zakfleming
    Aug 17, 2007
    48
    Thanks for your help guys
  13. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Express Talk
    SipX phone
    eyeBeam
    X-lite
    SJ
    3CX Phone(old version)
    3CX Phone(new version)
    All of them work like a charm...
    Did I miss somethings?
  14. VladislavA
    Jun 9, 2007
    30
    X-Lite (X-Lite3_29712.exe) doesn't support the Transfer Call feature.
    You can upgrade it to the eyeBeam 1.5. It costs some money.
  15. VladislavA
    Jun 9, 2007
    30
    You must use a headset with a regular PocketPC device. In duplex mode embedded microphone and embedded speakerphone create positive audio feedback and audio conversation becomes impossible.
    Moreover Windows Mobile smartphones free of the positive audio feedback.
    I tried SJPhone (PPC 2003se) on Windows Mobile 6.0 smartphone.
    http://forum.sjphone.org
