Recommendations for an ATA?
Discussion in '3CX Phone System - General' started by seanbts, Nov 10, 2010.
  1. seanbts
    Oct 12, 2010
    34
    Hi All,
    Looking for recommendations for a ATA that will allow us to connect a Credit card terminal to 3CX?
    Cheers
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Not sure if this is even support on VoIP, VoIP was never desined to handle data communications, only voice. said that fax was supported after the development of the T.38 codec so this might be a future supported application, but at the moment, i very much doubt that you will find a VoIP provider to support the process of processing credit card payments etc.
    The best opton would be to find a credit card processing provider that provides a terminal that can connect to your network via RJ45 connection and process the transcations via a internet connection.
  3. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    We have done well with the PAP2 on 711u (force codec, choice 1 only). Worked for credit card machine and alarm.
