Recommended FXO for overhead paging
Discussion in '3CX Phone System - General' started by leejor, Apr 2, 2016.
  1. leejor
    10,842
    299
    Assuming that the paging system is capable of simply being plugged into a telephone socket, dialled, and it answers , you page, then you hang-up, then any basic, single line, ATA should work for you. There are a number available, here is a link to configuring the basic Cisco model(s).
    http://www.888voip.com/configuring-a-ci ... -with-3cx/
    An ATA has a FXS port, by the way, that goes to a phone (S=Set), a gateway has an FXO port (O=office, as in central office), it plugs into a phone socket in the wall.
  2. 12494
    12494 Member
    Apr 16, 2010
    298
    30
    SNOM PA1 is a good device and it has provisioning template in 3CX.
    Allen
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,397
    273
    Snom is solid if you are connecting to existing Horns or Speakers. I've used Horns both with and without power. It does have a small amplifier built in and runs on POE.
    If you can get the budget - the CyberData VoIP Speakers are great.
    If you do not need zones - try 1 SIP Speaker then add slaves.
    I use this setup for a big Cubicle Area in a new office.
