Recommended FXO gateway
Discussion in '3CX Phone System - General' started by regfixit, Sep 27, 2008.
  1. regfixit
    Mar 7, 2008
    35
    I currently have a Linksys SPA3102 and am finding the call quality is very poor. I've spent hours looking on the internet and trying different tweaks to the SPA/PSTN gain, echo cancellation and suppression settings, but it seems basically impossible to get decent call quality. Can anyone recommend a good quality FXO gateway - I only need one port, but would be prepared to pay for decent call quality even if it meant having redundant extra FXO ports.
    I've seen mentioned the Grandstream 4104 and the Patton 4114, but with sometimes contradictory reports about quality.
    Could anyone share their experience/recommendation ?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    If the cost of it not the issue. I would like to recommend SN4114.
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    I tried SPA3102 and GXW4104 and both works fine with 3CX
    try to set it again after restore factory set
  4. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Id vote for the 4114 as well.
  5. cristianoiai
    Oct 5, 2008
    Hello!
    I am successfully using a Gateway FXO ports of two of WELLTECh ( http://www.welltech.com), easy to configure and works very well. Do not lock the PSTN lines. Very good!
    Hugs;
    Cristiano Pereira
    AC Technology
    Brazil - Santa Catarina - Itajai
  6. brunogaray
    Jan 15, 2010
    Oi Christian
    pudes me dizer como configurar o 3CX q PSTN
    WELLTECH Registei-me mas não pode obter o tom PSTN
