Recommended Hardware for the SBC
Discussion in 'CRM / Helpdesk / App Integration' started by Bruce Coleman, May 9, 2017.
  1. Bruce Coleman
    May 9, 2017
    What hardware are you using for the SBC environments. We are hosting the 3cx in our data center and deploying phones at the customer site with a SBC. We have used Raspberry Pi as the hardware and we have loaded the 3cx SBC on local pc's. Is there a hardware SBC that has been used? What is being used at the customer locations with 100 telephones or less? I want to standardize on a reliable piece of hardware as the SBC.
    Thanks in advance for the recommendations.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
  3. Bruce Coleman
    May 9, 2017
  4. YiannisH_3CX
    May 10, 2016
    7,783
    564
    The hardware requirements are the same for both the SBC and the PBX but those are dependant on simultaneous calls and not registered extensions.
