- Joined
- Jun 11, 2017
- Messages
- 14
- Reaction score
- 4
Hi 3CXers, I was researching what would be the best partitioning scheme for the 3CX Debian version for reliability and optimum performance. BTW, I've found The Linux partitioning guide by Pollock to be a really good read...here's the link to it: https://wpollock.com/AUnix1/Partitioning.htm
At the time of writing, neither the training nor any of the other posts address this. the basic Training video simply suggests to put everything on one partition, but i don't think this is likely to give optimum performance.
I looked at partitioning recommendations for Asterisk, Cisco CallManager, and Avaya IP Office Server edition and I am seeing multiple partitions, particularly for Cisco CM.
So far this is what I am thinking (using an esxi vm with 4gb ram and 500gb drive in Raid 1 config):
root "\" 400gb (this is what ever is left over from the allocated space for the other partitions)
var - 85gb - log files location, with possibly a lot of read/writes, therefore a good candidate for its own partition
swap - 6gb ( based on a recommendation for calculating swapfile size I saw on another forum)
tmp - 9gb VMware recommends the /tmp at least 1.5 times the amount of virtual memory on your system.
home - doesn't really need to be a separate partition. can exist as a directory under root.
This leaves about 400gB not specifically allocated and my assumption is that this will be used by the root "\" partition.
A so far unanswered, but big, question is:
Where on the Debian installation are the voicemail and call recordings stored?
These are typically the largest consumers of disk space and one would want to provision carefully for this and not run out of disk space prematurely. And knowing this could possibly influence the partition size allocation.
I hope someday 3cx will address this in a comprehensive way but in the meantime, I am reaching out to the community for your thoughts on this.
Thanks in advance.
ICNS01
Thanks in advance.
ICNS01
